deeretails
I recently purchased a 2020 that had been in a collision. The collision was sever enough that it broke the rear axle housing and destroyed the rear wheel and center section. The wheel center is steel, and the tire size is 36". I can't find a wheel center or rim. although if I found a wheel center I could get a blank rim and weld on the loops. The wheel center is #T31502 and the rim is #30617. Thinking about going to 38" tires, it was an option at the time. What thoughts or solutions do you have? The tractor had other damage, but that is relatively easy to repair, the hang-up is the center and rim.
