rustred
ok this tractor is giving me hydraulic problems. i checked the pressure at the couplers and have 2100 psi. once it gets warmed up it making that cavitating noise like out of oil. so this evening i put the guage back on and when you pull the hyd. lever it goes to 2100 then let go of the lever and the pressure slowly drops off. it struggles to lift an implement. plus at times it vibrates and just is not smooth running and you can hear that hyd. whine. is this problem in the control levers ? as it dont appear to be the pump. just like something is bypassing. the oil is foamy in the tank also. plus have tryed both hyd. outlets. both the same deal. yes oil level is full.
