tractor gal
My faithful 2N had been put onto the shelf for some tasks in lieu of another tractor. It sat idle for several months...number unknown...maybe 6? Anyway, prior to it idleness, there was no problem in starting...popped right off. When I was preparing to use it recently, it wouldn't start. I took a spark plug out and could not get a spark. It had been sometime since they had been replaced so with the nice weather, I decided to install the parts in the tune-up kit: new plugs, points, rotor, distributor cap. I also had a new coil that was installed, too. Result...no change.
So, I have seen some of the suggestions to try to determine cause of no spark. BUT, here's the real problem. The copper tab within the distributor that extends to the attachment point where it joins the metal strips from the points assembly has broken off. I don't think this is the cause of the original problem but will that broken tab prevent starting when I figure out the lack of starting...I think the battery is too weak for a strong start even though it tests OK on the voltmeter, 6.65. It is older (don't know how old) and I've kept a trickle charger on it but things don't last forever so a new battery seems reasonable. My biggest concern is this copper tab. I doubt that I could solder the tab back in. A confusing part is that a youtube showed a guy replacing points in a 2N and he said NOT to attach the tab but push it up so it doesn't touch anything. When viewing that I had questions of the accuracy. Why would there be a hole in that tab if it wasn't to attach or even better why would it even be there.
Any help would be appreciated. I tend to bungle things pretty well.
