So I recently got a 1996 310D Backhoe that's been sitting up at least a couple years. put a battery on it, started it up and drove it home. Operated it around the house for a little while. driving across the yard to pick it up it killed and took a few minutes of sitting before it started back up. Had to pump the throttle a little to get it going. parked it. next day it starts up fine and i operate it for 30 mins or so and it kills. wait about 5 mins and with some throttle pumping it starts back. operates shorter amount of time then slowly kills.
The longer you let it sit the longer it will run. I've been working on it the last few days. What I've done so far........
Replaced fuel filter
Replaced injectors (had some fuel leaks around them) one of the new ones won't stop leaking slightly around the injector nozzle hole
Replaced the Diesel
blew out the return line from the injectors to the fuel tank with air
removed the fuel transfer pump to see if it was functioning (seemed ok?)
removed the check valve on top of the injection pump (its functioning) ( i can blow air one way and not the other)
disconnected/reconnected the injection pump solenoid (its clicking)
Replaced the Diesel
