620 John
At some point I'm going to covert my '51 B to 12 volt. Might be pushing snow so it would be nice for starting if it's -10F outside. Plus I might change the lights to something brighter. I know this topic has come up from time to time but I'd like to get some more specific information before I decide how I'm going to do it. The tractor is more of a workhorse than a parade queen. However I don't want a butchered up ugly mess when all said and done.
Currently the tractor is 6 volt positive ground with what I think is a reman generator (it says Wilson 110390 so I think it's a Delco reman). It also has a Wico XB distributor on it. I know this distributor isn't the best but it seems to be working pretty good (I've got new points, condenser, rotor, cap, and coil). For the time being I'll just add a ballast resistor so I don't fry the coil. Some day I might upgrade to a Delco distributor and put electronic ignition in it. Here's my thoughts:
Charging:
I'm leaning towards going with a 1 wire alternator. This would really be beneficial if I want to put better lights in it. If I go this route I know I'll have to switch a few things over to run negative ground. I'm not familiar with what specific alternator models are out there though. Would also like to know the best way to get it mounted and what pulley to use. Another thought is if I want to keep it looking original how hard is it to convert the generator to a 12 volt?
Starting:
I know my starter needs to be rebuilt. Little while back I did a free running Amp test to see how many amps it was pulling. Using a Fluke clamp amp meter and fully charged battery the starter was pulling about 110 amps. Spec in SM-2029 is 60 amps for the 1107942 starter. I did the test with starter still installed and just took the bottom cover off and hit the starter switch with my finger so the bendix wouldn't engage the flywheel. From reading past topics it seems like a lot of people don't have any issue running a 12 volt battery on a 6 volt starter. However if I'm rebuilding the starter it might be wise to change whatever that may be needed to run 12 volts. I see someone on Ebay sells some sort of conversion kit. I'm also going to replace the battery cable but won't do that until I know for sure which polarity I'm going to use. Will also run a ground cable to somewhere on the frame instead of the battery box.
Ignition:
As I said before this tractor has an XB on it so I know I'll have to add a ballast resister. I'm thinking one of those resisters off of a 20 or 30 series tractor should work. I will switch the wires around in the coil if I go with an alternator. I'm sure some day I'll switch to a delco and electronic ignition but that'll be another time.
My main questions are:
What model 1 wire alternator would you recommend?? I see Steiner sells a 63 Amp (p/n ABC418) would that work?? What type of pulley?? Best way to mount it?? (pics would be nice). How hard is it to convert the 6 volt generator over to 12 volts??
What's involved in rebuilding/converting the starter for 12 volts?? Tips/tricks for rebuilding a starter??
Charging:
Starting:
Ignition:
