94onthefloor
I recently purchased a 52 8n converted to 12v. When I initially started it I noticed it had a slight miss. I bought new plugs and wires for it as they were old and the plugs were not correct. While doing this I realized the plug wires were not in order on the cap and pulled the distributor and reset the timing. After doing all that it ran like a top and I thought it was good to go until it stalled about a 1-2mins of it running. I then proceeded to replace the coil, ballast resistor, and ignition switch as they were all heavily dated. I proceeded to start the tractor and still came up with the same stalling problem. I then pulled the carb, fuel line, and sediment bowl. I cleaned all these parts along with the tank and put it back together. I started the tractor with high hopes and it seemed to be running great so good I started my way to my brush hog nestled in the woods when the tractor then again stalled after a little bit longer time period than before maybe an extra minute of run time. When the tractor stalls I can hear a fluid what I believe to be fuel running down the line. I m not sure if that s an indication to the problem or if it s something else. I have not been able to inspect the points or condenser due to not knowing how to remove the rotor to remove the points cover that is also facing away from the oiler. I know this isn t right either. If anyone could give me tips on things to do/look for or how to remove the rotor to access the points and condenser to replace those as an extra set came with the tractor that would be great!
