Two of my quick connects for the loader control lines are dripping badly. I tried replacing the o rings but still leaking. I see no reason why these should not seal when I examine it as surface looks smooth. I dont believe I have any trash on sealing surface.. Does the quick connect sealing area [ where the oring seals against ]simply wear out to the point they wont seal? Also, how do I size them? Should I just remove and hope parts store can match as I did last time ? Also, the quick connects were hard to get back on, much more so than when I removed them a few years ago and yes I had the bucket sitting on the ground to reduce the hydraulic pressure.
