I have a 1938 Allis Chalmers B with a hand crank start only.
A little back ground, It was my grandfather's and while I have never seen it run, I recall my father saying that they could only get started by tow starting it.
After sitting a long time in the barn (30+ years) the engine was stuck solid. I removed the cylinder head to free up a stuck piston. I cleaned up the head and valves. Then checked and adjusted the rod bearing clearance (applying some engine assembly lube in the process).
But the engine still seems "stiff". I can move it by hand spinning the cooling fan. But it seems to take more effort than I would expect.
When I try to use the hand crank I certainly can't get what I would consider to be any reasonable momentum behind the spin. It's really stiff and often "pushes" the hand crank back out.
To be clear I am not talking about it almost starting and the momentum pushing the hand crank back out. What I mean is the resistance is so much that when applying torque to the hand crank, instead of rotating the engine, the hand crank pushes itself out. (I have started to wear shiny spots into the crank pulley as a result of this).
I had hoped that when I tried to tow start it, it would get the oil circulating and lubricate things and make it better. Sadly my timing was off so I couldn't get it started, but the engine did seem to turn over just fine. But still, the engine behaves the same.
I would appreciate any thoughts on why the engine might still be so stiff.
