I recently obtained a 1990 Case-IH 395. Among other things the alternator wasn't delivering. I obtained what was said to be a direct replacement which satisfied the geometry and electrical plug in connector that suited my tractor. Right now I don't remember (senior moment) if I checked it after installation...may have and probably got good readings, but maybe not.
I have the wiring diagram (full set of SV manuals and parts book) and it shows the 3 pin connector with 2 high current windings connecting via the starter solenoid terminal to the battery. The third is a low current sense wire (brown/black stripe) and goes to the instrument panel to say when the alternator is charging.
Well, nothing is happening. Both high current terminals read exactly the same voltage.....as one would expect as they are both tied to the same point...to the battery, and the sense wire starts out at about 0.18V at 600 RPM and moves up to around 0.33 volts at mid RPM. I see no reference to an external regulator in the wiring diagram as the alternator seems to be self contained.
Comments appreciated.
I am going to post this over in the Case site also.....one reason is Case penned the manuals.
