Nyquil Junkie
A while back the power steering pressure line cracked at the flare, in the port right behind the steering tower. I out a new line on and it worked fine and dry for about 3 months. yesterday it started to ooze and dribble from the same fitting. It was tight, nothing happened to it... so go figure.
I took it off and stuck my phone back in there to see whats going on and I se the flare face is badly worn and banged up. I will assume that in hot weather the seal was good and when it went down into the 20s it all shrank and shifted enough to leak? I dunno.
Is there any way to repair or seal this? the flare cone is in the steering tower itself, so replacing it means replacing the whole steering tower... I assume.
I need to seal this fitting good enough to move the tractor around now and then, I dont care if it weeps a little but not dribbling and oozing like a gunshot wound.
The tractor is 63 ford 4000 industrial.
Any help yall can offer I appreciate. Thanks
