Sean in PA
(quoted from post at 16:21:39 12/22/23) Because these steering cylinders do not have circuit relief valves in the system. Circuit reliefs are often used to protect
cylinders in many industrial applications. They are designed to open when the cylinder is subjected to a highly unusual
external force, like say using a front-end loader bucket as a dozer blade. Circuit reliefs are typically set much higher than
system reliefs. As an example, a front-end loader might have a system relief set at 2500 PSI, and circuit reliefs set as high
as 3500 or even 4000 PSI.
A steering cylinder can bend when the wheels suddenly drop into a deep hole. Since the cylinders do not have circuit reliefs,
they bend, or crack a spindle, or break a tie rod end, etc.
Some folks have reported bent cylinder rods from just holding the steering wheel at full stop for an extended period.
