Idaho cowboy
I am looking at replacing my older and getting tired New Holland swather with a Reese model 2070 HL drum mower, (NOT A DISC MOWER). I am curious as to how they work in Timathy and grass mix hay. Most of my ground consists of smaller fields that are fairly flat, but a couple fields are on sloping ground however not real steep. The manufacture recommends at least 45 hp. My tractor is a Ford 4610 with 53 hp. I was told that if the hay is laid down that the drum mower will pass over it without cutting it. I usually don't have an issue with down hay, so this doesn't really concern me. What experience have you fellas had with drum mowers, and do you think the Reese 2070 HL would be worth serious consideration? Thanks, Steve
