Hi folks,
I have a 1944 Farmall A with a Zenith 52499 / 9752 carburetor that is in pretty rough shape that needs to be repaired or replaced. A complete repair kit is $ 55 while a new Zenith carb is $ 400. This is what I found so far. One of the mounting flange holes on the carb to intake manifold is broken. Have a fix for that one. Not pretty but it works. The brass shaft for the choke butterfly broke in two. The repair kit supplies both throttle & choke butterfly shafts complete with the brass bushings.
Need some help with the following. How do remove the brass butterfly shaft bushings & replace with the new ones ?
What is the best way to remove & replace the brass Welch plugs ? Should you use something like a Loc Tite product or install the new plugs dry ?
There is a brass Welch plug located at end of the throttle butterfly shaft. Not sure if that plug needs to be removed to remove the shaft or is there a passage way located there that needs to be cleaned out.
I ran the carburetor through a ultrasonic parts cleaner numerous times but will also run a wire through the passage ways as well. Thanks for any helpful info or tips you may provide.
