FarmerBlair
I noticed the pto slipped on my 1968 Ford 4000 while rototilling. The slip clutch on the tiller itself was too tight, so the slippage occurred at the tractor pto, enough that it nearly stopped turning. There were some spots where I got into some heavy sod and clay soil. But I'm also tilling only 3-4 inches deep. I was at about 3/4 power. I noticed right away and stopped the pto. It did not bog down the engine when it happened and I would not have known it if I wasn't watching the whole time.
The tractor is an 8 speed with independent pto that uses hydraulic braking/engagement.
My question is, if the tractor pto is in good shape, should you be able to stall or nearly stall the engine if the pto gets bogged down? I'm wondering if I need to look into replacing the clutch pack in the pto. It works fine when mowing with flail or rotary mowers. The tiller works fine in looser soil.
New Holland said they could put it on a dyno, but would cost a few hundred dollars just to do the test.
The lever pulls up to activate the pto and is on the left side of the tractor.
The pto does not engage until the last inch or less of the lever travel. That probably doesn't matter since it actuates a valve, but seems like where 80% of the lever movement doesn't do anything has me wondering.
Thanks!
Thanks!
