[email protected]
For those of you familiar with the old 555, the three main hydraulic lines for the excavator run next to the right side frame. One of the three, T's into the frame via a threaded fitting at the spot where my leak is occurring.
I have a leak at the T. I cant quite tell if the leak is from the frame, or from the T fitting/rear pipe, but the frame will drip with fluid. I guess there is a possibility of a pin hole or crack in the frame.. it appears to leak when running so i suspect a pressure related issue.
1) does anyone know the fitting size at the T? The rearward pipe at the T has a dent just behind the female thread coupler that may be the issue. I'll just have a line made to replace the pipe. Curious if anyone knows the size of that line and ends, so i can stop and have one made without removing anything.
2) is the extra reservoir of the frame required? If there is a leak in the frame section the T is screwed into, can i remove the T and just run a straight coupler?
