I've got a late model Ford 6600(Australian) that my grandparents bought new in 1979.
The original gauge cluster was stuffed, water damaged and all the wires eaten by rats. Looking online all the 6600 gauges I found had the older style bimetallic gauges. The exact match to what was originally in the tractor appeared to be the early 6610 gauge set which I tracked down and bought. The original and the new guages both appear to have magnetic gauges. I wasn't keen on the completely different looking aftermarket gauges.
The problem I'm having is this gauge set reads the temperature just on the red zone when at operating temp and 1/4 cold when cold. I've checked with an infrared thermometer and most locations on the engine are near 182 farenheit when working. I also remember the original gauge worked correctly when I was a teenager years ago.
I then tried to buy a new sender but for a 6610 as i'm assuming earlier 6600 are bimetalic and different resistance. New sender has the gauge just touching red when engine is cold.
Measuring resistance I get
Original sender = 205 ohms at 180 fahrenheit and 870ohms at room temp.
New sender = 110 ohms at 180 fahrenheit and 202 ohms room temp
The old and new temp sensor.
Which wire goes to which terminal on the gauge? Perhaps i've screwed up the wiring???
What is this? - This was connected to the old gauge set inline what I'm guessing is the power terminal.
