I have a Ford 860 with a Ford 311877 single spool remote on it. Works like this one at Steiner: https://www.external_link/FDS3364-Single-Spool-Double-Acting-Hydraulic-Remote-Valve-Kit, but it's not that one. If it helps, I can show some pictures of mine. Has one handle, for a pair of hydraulic lines. Has a knob you can turn to work with a single action cylinder or double action. It also has an extra port they call an "auxiliary port", that's basically always fed with hydraulic fluid.
I bought an old log splitter to use with it. The log splitter has its own remote of course, and has two hydraulic lines coming off of it.
My first thought for hooking up the splitter was to use the two existing hydraulic lines coming off my remote. But I figured that would require that I pull the control arm on the tractor one way (it's a spring-loaded arm, so it wants to return to center if you're not pulling it one way or the other) the whole time I'm using the splitter.
When I read more about the auxiliary port, I figured that was the way to go. So, I bought parts to run a hose off that, and planned to hook up one side of the splitter to that, with the other line from the splitter going to one of the remote's controlled lines.
First, I connected the auxiliary port to the splitter with the lift arms down (the shop manual says the auxiliary port uses the same flow as the lift arm cylinder), and with the other side of the splitter with an open hose going into a bucket. I wanted to flush the old fluid out of the splitter, and that worked just fine - I raised the lift arms some, and the fluid (old black nasty stuff) came out the other hose and into my bucket. I got about gallon out before the fluid looked normal, and dropped the lift arms and disconnected the splitter from the tractor. Then I added hydraulic fluid to the tractor to get it back to full.
Then I tried to hook the splitter back up again, with the return hose connecting to one of the remote's top two lines, and the other line from the splitter going to the auxiliary port hose. Here's what happened:
- I raised the lift arms, and they went up.
- I tried to use the splitter's remote, and it barely moved at all. Moved about an eighth of an inch a minute.
- The lift arms on the back of the tractor would - about every 20 seconds - jerk downward a tiny bit then go back up.
- The lift-arm-drop-and-rise was when the log splitter cylinder would move a tiny bit, not moving at all otherwise.
I thought maybe I should have used the other line on the tractor remote, so I swapped them, but got exactly the same thing. Once I disconnected it, the lift arms on the tractor worked completely normal.
I've got three guesses for what I did wrong. I mentioned at the top that tractor remote has a knob you can turn to work with single-action cylinders. I didn't change that. So, that might have been a problem. Second, in my manual for the remote, I just realized that it says:
"NOTE: When utilizing the remote valve auxiliary port connection for operating a remote cylinder, hold-down arms should be used on the tractor lift arms if the remote cylinder has an equal or greater cubic area than that of the tractor ram cylinder."
Third, of course, I may not know what I'm doing enough to hook this up right!
Any suggestions for how to set this up right? (And, yeah, I know the tractor's hydraulics are going to move the splitter *really* slowly. I just figured it would be faster than an inch every ten minutes...)
Thanks!
Thanks!
