Hello Ogrumpyone welcome to YT! Never worked on
one of them carbs they look to be a little more complex
then needed for an old tractor, probably make anybody
grumpy. What is the condition of the tractor? Are you
trying to get it running after it had been setting unused
for a time. A crudded up fuel system from setting with
bad gas in it is not an easy problem to overcome. It
looks like the screen in the fuel pump number 5 in the
link is the only filtration in the system. Did you
look at it is it intact? If dirty fuel is a problem with your
machine you may just have to bite the bullet and cut
the fuel line between the fuel pump and the carb and
install an in-line fuel filter. I am guessing as Jim
suspects that your float needle valve is simply not
shutting off because of debris in it and the fuel level
gets to high in the carb. Since it will not just drip out as
it would in an updraft carb you may have to loosen the
carb and pry it up a bit and slide a screwdriver under it
to hold it up a bit. Pull the coil wire and crank the
engine 5 seconds or so. Now watch the bottom of the
carb through the gap, I bet you soon see gas dripping
down from the carb because the float needle is not
sealing. I would add the filter in down after the pump
so the hoses for it are exposed to less heat. You will
also have to make sure the inside of the fuel line going
up to the carb is clean inside so nothing is coming
loose to get in the float needle, rod it out with a wire,
then a shot of carb cleaner and finish with a blast of
compressed air.
CNHI IH 354 parts catalog
