Installed new ignition switch and she started up fine. Changed all fluids (oil/trans/hyrdo) then went to start it and it cranked then suddenly stopped. I jumped the PTO and the Gear solenoids to rule them out. Still nothing, no starter solenoid click nothing. Placed wire on + battey terminal to starter solenoid, it clicked so ruled the starter solenoid out.
Testing aftermarket ignition switch:
Tested on the bench, the B terminal reads voltage, with key in the start position the C(ST) terminal reads voltage so this looked good to install.
Now when installed on tractor the B shows voltage but with key in start the C(ST) reads nothing. I am going out of my mind , spent 2 days on this and went through 4 ignition switches! HELP!!!
