joshbruce128
Ford 851 Chattering....? Not sure the best word to use here. Chattering comes to mind. When lifting, my arms shake, chatter, shake as iff they were being raised over an enourmous file. I wouldnt descride it as hiccups, and it doesnt fall, it just.... chatters.... why?
-I rebuit the lift cover with new o rings.
-popped out lift valve and cleaned, not binding.
-popped out unloaded valve, replaced o ring, cleaned, not binding.
-Replaced worn control lever pin.
No bubbles in hydraulics indicating a leak or sucking air.
-When lifting, it's strong, lifts my 750lb mulch layer.
-I am pretty certain things are out of adjustment because when my control is halfway up, my lift arms come all the way up. Just not sure if the adjustment could cause the chattering. My gut says no, but I will be adjusting asap.
Any thoughts on what is causing this? I'm wondering if I have a bad or stuck ball in my pump, causing an uneven amount of hydraulic pressure when force is applied by the pump. But, I didn't see that as a possible cause in the IT manual, just my slightly educated guess.
