So I recently doubled the Case fleet with a late model (1969?) 440 + Case loader to keep my 311B company. Likely got plenty of questions to come down the road, but the most pressing at the moment are:
- looking for service, parts, and ops manuals. Is there a particular part/manual number/series I need to get to cover the changes mine has benefitted from over the years? I've got an earlier version of the 430 parts manual (RI A402) that doesn't cover a lot of mine (like the diff lock, Draft-o-matic 3pt, twin cylinder power steering, dual range trans w/o shuttle shift, etc). Want a manual for the loader too, which leads to...
- where can I find the loader model/serial plate/# - no joy yet, but I've been known to look right past the obvious sometimes. Did a model 22 come with twin bucket cylinders? Only 22's I've seen so far have a single in the center. Also, this one is plumbed direct to the levers/valves down beside the seat and Draft-o-matic, not to a separate set of levers up on the right loader mount post.
- TractorData.com says the weight of a 440 is @ 1000 lbs less than my 311B, which I find REAL hard to swallow - CAT scales say my 440 + loader weigh @ 5800 lbs. Previous owner says tires aren't filled and the rims look good, not eaten out like so many other filled ones, although TData says rears should be x24s while mine are x28s - not original rims maybe? Would a guesstimate of @ 4300 lbs be reasonable for just the tractor + @ 1500 for the loader?
Got a few other issues to work on - pto won't disengage, clutch is grabbing at the very top of the pedal, brakes are meh at the bottom of the pedals, fixing a small gas leak at a bum compression coupling, nothing particularly unexpected.
Thanks in advance!
Thanks in advance!
