Tree-Farmer
I went to use my grain truck and it's making a funny noise.
When I put the PTO in gear and let out the clutch, it made a loud, unusual noise, hard to describe.
1973 F600 grain truck, worked 6 months ago, I could raise the bed before. Has a 330 motor, 4 speed transmission, 2 speed rear axle.
The noise happens when the PTO is running, I didnt try to raise the bed.
What can be wrong with a PTO?
I assume I need to check the oil in the transmission. How do you check the transmission fluid in this truck?
Does the PTO use the same reservoir as the manual transmission?
What else could it be? Thank you for any comments!
