Anonymous-0
The splines on my PTO (52 8n) are all buggered up. That must be why the PTO pops out of gear often when I'm bush hogging the meadow.
I've been reading the archives and it appears, with luck, that the PTO shaft should just slide right out when I unbolt the four bolts.
And, yes, I know I need to park her downhill or drain the hydraulic fluid first. The fluid is fresh and clean so I don't want to replace it when I do this job. Anything else I should do while I've got the shaft out? It's leaking now so I know I need a new seal. Are new bearings included with the new shaft or should I replace them?
When I get this done, I want to finally install an ORC. The archives indicate there are various styles and qualities. Can you guys please recommend a good one? And a place to buy it?
Another question about ORCs. I read somewhere that the ORC allows the PTO shaft to free wheel if the implement exceeds the PTO speed. Is that right. I nearly always have to exceed 540 rpm when I'm mowing my meadow. It's too thick to run it so slow. It will never get the job done if I can't keep the tractor running around 1800 rpm or so. Will the ORC really keep me from doing that?
Should I also install a sleeve that totally encloses the ORC and implement shaft? Where do you get these things?
