This message is a reply to an archived post by kentbigbuck on November 28, 2020 at 19:43:38.
The original subject was REBUILDING POWER STEERING CONTROL VALVE ON FORD 2000.
I'm in the process of rebuilding this valve. My steering shaft has what looks like 2 grooves worn in it. It looks like it may have been welded and turned on a lathe at some point in its life to repair the groove that the seal wore into the shaft. I have the Speedy Sleeve and seal repair kit but, I can't tell where to place the sleeve. Does the sleeve sit all the down against the threads or should I place it about 1/4 inch up higher where it looks like there is a groove. I hope this makes sense. One of the grooves looks like it may be a leftover mark from where it was turned on a lathe. Thanks in advance.
