When I bought this 240 the Quandrant Levers, 3-point hitch levers, were seized together, probably from years of not being used. Finally I removed the trans top cover
and turned it upside down on the bench to get the lever rods loosened and moving indepentently. Now!! Trying to replace the top cover! Apparantly there is a sneaky way to position the lift control lever which protrudes downward, and right beside the lift ram. First attempt I found the Position Lever spring-loaded and won't stay down, springs upward. Can't be right! Second try I find the two levers both loose, like they should be, but starting the engine causes the lift arms to raise, and nothing I do will lower them. So, does anyone know the trick to positioning this activation lever in the proper place when lowering the transmission cover into place? Thank you for any suggestions.
