MARK ROBKE
I live in northern KY, so our weather is similar to yours. Whenever I store(d) bales outside they lose the first 6-8 inches on the outside, which is a BIG part of the bale, volume wise. Even after just 2 1/2 months. I ALWAYS butt them together as tight as I can. This does seal out moisture on the bale ends. The bottom stings will rot too, so if you can, set them on pallets, or old tires. I have fed them and been surprised at how much of the rotten hay that the cows eat, but there can't be any nutrition in it. I now have a building for my rolls, and still stack part of it on pallets, and the rest on top of loose hay on top of gravel on top of filter fabric on top of plastic. And even that hay gets funky on the bottom if I don't use it the first year.I got a feeling we will be making a goodly number of 4x4 string tied round bales this year with our JD 335 round baler beyond our squares. We will barn store as many as will fit, however…
There will probably be a need to store some rounds outside.
We will store end to end (not stacked) on well drained ground with space between the rows, uncovered.
Question - what percentage of hay might be lost due to weather?
Do you have a loader with a hay spear? You can stack your inside hay, and it will fit best if you set the bottom 2 layers on end and set the top row on its bottom as it came out of the baler.
If you sell all your hay as I believe you do, I would sell what don't fit in the barn straight out of the field at a discount and the storage problem is the buyer's problem, not yours. Mark.
