Torque tube
jdoc4287
Torque. Tube on case 300 triple range comes out of top cover of 3pt great case. Where does open end route to? It is pumping oil all over everything.
Your hydraulic oil is traveling into the transmission/differential area either from the pto seal or leaking from bad seals on the internal lift cylinder. Every ounce of oil you add to the hydraulic reservoir transferrs and when too full the oil will come out the brakes and top. Ask your question on the Case forum for more information.
Hello jdoc.., welcome to YT! This site changed formats at the end of last year. I think it is fairly easy to navigate to the other topic forums now but still may be confusing. Click the red tractor silhouette at the top left and the forum list will show. Then scroll down, the Case forum is in the Manufacturers section.
