I'm working on the WD9 tonight and I found the rack was stuck in the pump. I got the rack loose and working properly and fired it up again to switch it to diesel. This time I got some success as it switched over reasonably well as it ran on the diesel the first time since I got it. It was RPM hunting though and sounded as though it was probably missing. I loosened the lines on the injectors and found the engine would about die on 2 and 4 and fuel was coming out of them but cylinders 1 and 3 had no change when I cracked the lines and no fuel except for one time where I had some fuel pressure on 1 until I loosened the line and then fuel shot out and I had no pressure again.
I'm not familiar with these pumps as of yet and am just reading what I can find on the net. I'm guessing I have a plunger or something stuck and I'm not able to find what I need to do to try to free it up like I did with the rack.
Any help with what is going on and how to resolve it without sending the pump out would be great.
