Tractorcedric
- Location
- Garland. Utah
So I bought this blade at a scrap yard the other day. I think it was mounted on some sort of four wheeler. It had a long piece of 2x3 tubing that was linked to a one inch square piece to go into the rear hitch. The tubing was all bent up, so I have cut it off right were the blade angles. I can't decide if I should weld a new piece of tubing onto it and push from the center of the tractor. Or just mount it to the two mower brackets in front of the front axle. Also the blade is not too heavy, but it is four feet wide. If I push from the center of the tractor, I could fix a lever to lift it with the front brackets. If you look close you can see the end of the tube were I cut it off. The blade has springs that let it tip over if you hit something solid and it angles. Behind the seat of the tractor is a platform that my sprayer sits on. I could stack some flywheels on there for more traction. Tractor is a hydro.
