Home |Gallery |Forum |Ads Sponsored by Yesterday's Tractors
Yesterday's TrucksThe Classic Truck Resource Page
Vintage Truck Headquarters
Featured Photo
Click to View
Features
Discussion Forum
Forum Archives
Truck Photos
Model Profiles
Truck Links
The Market
Picture List
Contact Us
Antique Tractors
Kountry Life
Tractor Manuals
[Home]
This is the modern view of the Yesterday's Trucks Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
1990 Chevy K1500 Front Axle Question
Post new topic    Yesterday's Trucks Forum Index -> Yesterday's Trucks
wsmm
PostPosted: Sun May 20, 2018 6:57 am    Post subject: 1990 Chevy K1500 Front Axle Question Reply to specific post Reply with quote
Does anyone know if you have to disconnect the front sway bar and the right sway bar link plus the right tire rod from the drag link to remove the right side axle tube containing the axle? I know I need to unbolt the outer axle shaft from the housing, but can you then just disconnect the electrial connectors from the axle tube, remove the bolts from the differential and take it out?
Thanks,
Bill
Pocko
PostPosted: Sun Oct 07, 2018 8:23 pm    Post subject: Re: 1990 Chevy K1500 Front Axle Question Reply to specific post Reply with quote
wsmm wrote:
(quoted from post at 07:57:44 05/20/18) Does anyone know if you have to disconnect the front sway bar and the right sway bar link plus the right tire rod from the drag link to remove the right side axle tube containing the axle? I know I need to unbolt the outer axle shaft from the housing, but can you then just disconnect the electrial connectors from the axle tube, remove the bolts from the differential and take it out?
Thanks,
Bill
I believe that you will still have to open up the carrier cover,remove thecenter pin from the carrier to gain enough room to push the axle inward to remove the axle retaining clip,( looks like a large thick washer that is missing about a 1/3 of it ) some call it a C clip, hope this helps.Truckintom
Post new topic    Yesterday's Trucks Forum Index -> Yesterday's Trucks All times are GMT - 8 Hours
[Home]
Copyright © 2002-2013 YesterdaysTruck.com
Antique Truck Headquarters
