Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Bobcat tire pressure
Post new topic    Today's Tractors Forum Index -> Tractor Talk
Bryan in Iowa
Guest
PostPosted: Sun Sep 28, 2008 10:46 am    Post subject: Bobcat tire pressure Reply to specific post Reply with quote
Using a buddies 843 Bobcat skidloader . Tires seem squishy . Can anyone help me out with correct tire pressure , 12 16.5 tires .
Thanks
oldrustycars
PostPosted: Sun Sep 28, 2008 11:24 am    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
10 ply, 60 psi. 12 ply, 35 psi
View user's profile Send private message
No tools
Guest
PostPosted: Sun Sep 28, 2008 1:09 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
You want about 80 psi in them.
oldrustycars
PostPosted: Sun Sep 28, 2008 2:02 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
http://www.bobcatcountry.com/parts-tires.html
check this out and decide for yourself
135 Fan
Guest
PostPosted: Sun Sep 28, 2008 4:40 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
These are Bobcat tires, not truck tires. Look what it says on the side wall. Probably not anywhere near 80 PSI. My skid steer has 10:00- 16.5 and they are 35 PSI. I don't think a wider tire would be much more, if any. Dave
RodinNS
PostPosted: Sun Sep 28, 2008 5:24 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
Look on the tire sidewall and it will give the advised inflation pressure.
I generally run the 10.00-16.5's on my machine at 50-55 psi and they say 50 psi on the sidewall. I'd think the 12's would be quite similar...
Rod
Iowa_tire_guy
PostPosted: Sun Sep 28, 2008 5:51 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
135 Fan wrote:
(quoted from post at 17:40:00 09/28/0Cool These are Bobcat tires, not truck tires. Look what it says on the side wall. Probably not anywhere near 80 PSI. My skid steer has 10:00- 16.5 and they are 35 PSI. I don't think a wider tire would be much more, if any. Dave
I think if you will read your sidewall closer you will find that it is saying to not use over 35 psi to seat beads. A 10-16.5 tire that only takes 35 psi would be pretty wimpy, like a 4 ply.
Pressure is determined by ply rating no mater what the brand. Refer to a chart or the sidewall to get proper rating.
135 Fan
Guest
PostPosted: Sun Sep 28, 2008 6:06 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
The owners manual says 30-35 PSI and refers to them as flotation tires. The original tires were 6 ply and the new ones are 10 ply, I think. I put tubes in them because if I didn't use it everyday, a couple tires would slowly leak. Very common on skid steers. Too much air and you won't have as good of traction and the ride will be a lot rougher. 35 PSI in the tires seems to work good. Bobcat tires are low speed off road tires. That must make some difference. My rear tractor tires are 6 ply and only take 14 PSI. My neighbor brought home a 644 JD loader and needed air in a tire and it only called for 16-18 PSI. That's a big loader. I did mention checking the sidewall in my original post. Dave
Iowa_tire_guy
PostPosted: Sun Sep 28, 2008 6:51 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
According to Bobcats Tire webpage they do offer flotation tires that use 30 and 35 psi. They don't show a 10-16.5 size in their brochure though. As you can see, most 10 ply rated Skid tires are to run 50 to 60 psi. Go to link below and click on pneumatic tires to the right. Charts is most of the way to the bottom. Thanks for showing me their flotation tires, did not know about them.
http://www.bobcat.com/partsandservice/genuine_parts/genuine_tires
135 Fan
Guest
PostPosted: Sun Sep 28, 2008 9:37 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
My tires might only be 8 ply. I just went with what the owners manual said and they work good. 12-16.5 could be 50 PSI. Most all skid steers come with the flotation tires on them already. Dave
RodinNS
PostPosted: Mon Sep 29, 2008 3:57 am    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
To be honest I didn't know there was such a thing as a flotation tire for a skid steer.
It may well be an option but I've never seen any equipped with them around this area.
Most are either on 10.00x16.5's or 12.00x 16.5's, also known as sink quickly and sink slowly...
What sizes are they running for flotation in your area?
Rod
Bryan in Iowa
Guest
PostPosted: Mon Sep 29, 2008 6:13 am    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
Thanks for all the replies ! Went to 50 lbs and WOW ,what a differance . No longer feels like it's gonna trip over with a full bucket .
135 Fan
Guest
PostPosted: Mon Sep 29, 2008 1:15 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
You don't hear of them called flotation tires because they are standard equipment 95% of the time. There are even wider flotation tires as well. On my machine (not Bobcat) which is a size smaller, the standard tire size is 7.00x15 and they take 50 PSI. The 10.00x16.5 take 30-35 PSI. Dave
RodinNS
PostPosted: Mon Sep 29, 2008 1:37 pm    Post subject: Re: Bobcat tire pressure Reply to specific post Reply with quote
I guess it depends on the machine...
I've got 10.00-16.5's on my LS170 NH and I can assure you, there's nothing flotation about them. They're the standard tire on that machine. Perhaps Bobcat's are different.
Mine call for 50 psi on the sidewall and are promptly inflated to 55 psi, with tubes. They're pretty squirly with less than 50 pounds air. I can't imagine running 35 pounds in these tires on this machine (1700 # operating load, 5500 # machine). It would be dangerous on this machine.
Rod
Post new topic    Today's Tractors Forum Index -> Tractor Talk All times are GMT - 8 Hours
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
