Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
4020 John Deere
Post new topic    Today's Tractors Forum Index -> John Deere
Ray Durham
PostPosted: Tue May 19, 2009 3:42 pm    Post subject: 4020 John Deere Reply to specific post Reply with quote
I own a 1964 John Deere 4020 (serial #21T85483). Fuel gauge quit working, so I sent it to Jerry Trcka at EverGreen Restoration to restore. Got it back still didn't work. Jerry suggested I get a new sending unit for the tank. I did, but still does not work. Now, Jerry is saying my gauge is a 0-30 ohm gauge and must be matched to a sending unit with this same ohm range. My mechanic says the new sending unit is a 0-300 ohm unit. I'm curious as to what other members of this list think about my situation.
View user's profile Send private message
nickg
PostPosted: Tue May 19, 2009 4:49 pm    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
I have a 67 4020 diesel. My fuel gauge hasnt worked since I got it and wanted to fix it so I went to deere got a gauge and a sending unit. Crappy thing still doesnt work and Ive tried everything. Re wired it made sure it was positivly grounded and everything. I read sum wear that deere had part numbers wrong on the gauges for a gas and a diesel gauge but dealership wont take it back and Im not spendin 80 bucks on another gauge so I just use my never failing trusty piece of dowl rod for a fuel gauge. Hope you have better luck than I did
Gerald J.
Guest
PostPosted: Tue May 19, 2009 5:08 pm    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
Check the wires and the grounding of the old sending unit. On mine I was able to restore the old sending unit by bending the brass wiper a little so it touched the resistance coil again.
Fuel gauges have to match the sendor's resistance range or they will not work right.
Gerald J.
tim s
PostPosted: Tue May 19, 2009 5:34 pm    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
If your 4020 has standard 24 volt system it takes a RE 54427 positive ground gauge, and AR 26434 sender,,If it has been converted to 12 volt neg. ground you will need RE 53664 gauge and AR 26434 sender,,and the gauge holder will need modified to fit the new style gauge, the orange wire is the sender wire..and a ground wire needs to be run to the gauge..
buickanddeere
PostPosted: Wed May 20, 2009 7:37 am    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
Swapped polarity on 12V tractors and 24V to 12V conversions can render a fuel gauge useless unless properly re-wired.
View user's profile Send private message Send e-mail
4020_1966
PostPosted: Wed May 20, 2009 7:50 am    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
When I did my 12v conversion (was the Deere kit) the manual said that the gauge may not work and listed part numbers if that happened. It worked perfectly so I have not had to mess with that. I guess some gauges and senders don't care if they are pos or neg grounded. They listed the same sender as Tim but AR 46271 (sub for AT 27153, R34262, and AR26716) for Fuel gauge as the "matched pair". They listed different #s for the newer 4020s.
Which btw if anyone wants a copy of the PDF file I scanned that has the conversion instructions with a copy of the wiring diagram for the <200999 "button" start 4020s let me know. The wiring diagram has some pencil scribbles on it from me troubleshooting some things and markign the "converted" electronics but it is easy to read the factory diagram thru them.
clearcreekaggie
PostPosted: Sat Jun 19, 2010 1:07 pm    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
could you email me a copy of the 4020 wiring 12v conversion
crimson_w_livestock@hotmail.com
thanks
clearcreekaggie
PostPosted: Sat Jun 19, 2010 3:56 pm    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
l
Last edited by clearcreekaggie on Sat Jun 19, 2010 4:02 pm; edited 1 time in total
4020_1966
PostPosted: Sun Jun 20, 2010 5:48 am    Post subject: Re: 4020 John Deere Reply to specific post Reply with quote
Yea I can get you the pdf, gimme a day or so and I can. Its to big for me to email out, I might be able to rescan it, that would save me some problems in the future. Which are you need it for? The early early or the early 4020? I can send the diagrams for either.
Post new topic    Today's Tractors Forum Index -> John Deere All times are GMT - 8 Hours
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
