Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Faulty hydraulics on 2130 john deere
Post new topic    Today's Tractors Forum Index -> John Deere
Murray Edgar
PostPosted: Sat Dec 25, 2010 6:47 am    Post subject: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
Front end loader will not lift evenly. Oil is topped up
buickanddeere
PostPosted: Sat Dec 25, 2010 7:27 am    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
Tilting or sagging on one side? Or is the loader shuddering, vibrating and making noises?
You will have to tell us more info.
Have you been performing regular scheduled service according to the operator's manual?
Did the problem always exist, slowly appear or suddenly occur?
Type of loader, loader control valve(s) and how is the loader plumbed into the tractor?
In Canada or have a tractor jockey special in the US?
Murray Edgar
PostPosted: Sat Dec 25, 2010 9:03 am    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
loader is lifting even.It has jerking action and than seems to take a hold.With the snow blower raised to maximum height the loader will not lift.It is a John Deere loader installed by John Deere.This problem has been getting worse.(Canada)If the filter on bottom of transmission was changed would this help? I think the pump needs to be rebuilt?
MSM
PostPosted: Sat Dec 25, 2010 10:09 am    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
Maybe try to lower the snowblower a little. Sounds like the rockshaft has an internal leak at full lift which is bleeding off charge pressure to the front pump.
buickanddeere
PostPosted: Sat Dec 25, 2010 11:14 am    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
I'm wondering if You know a Ross and Bill Taylor? Or any of the Howatts around Blyth?
The pumps themselves are reliable.Everybody runs out and rebuilds them before ensuring they have a supply of oil. Or if the oil they are pumping isn't leaking internally.
I've seen lots of loaders installed by the dealer that were not properly connected. If the loader is supplied from the scv remote, there is one source of trouble. On your Mannheim Deere the loader oil supply must be tapped into the high pressure line down by the brake cylinder. Return oil from the loader goes to a ported trans filter.
I assume the operator's manual has disappeared?1-800-522-7448 for a new manual. It shows where the trans pre-screen and mail filter are located and when to service. There maybe also be a wee screen in the front pump inlet.
The recent cold weather, has it made the vibrating worse?
The three point hitch position is a vital clue. A seal maybe blown internally and leaking high pressure oil. Have a look in through the trans oil fill with a strong light will the three point is in various positions. You should not see a spray or stream of oil from the rockshaft internals.
What kind of oil have you been pouring into the transmission?
Murray Edgar
PostPosted: Sat Dec 25, 2010 11:47 am    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
Even in the summer time when the 3point hitch is generally lowered and or not in use, the loader raising and lowering is not a smooth operation. Tipping and raising the bucket itself is affected aswell. We use trans hydraulic oil. Does it make a difference if we are using not JD oil? Have not tried looking in the hydraulic fill hole yet, but will, thanks.
Murray Edgar
PostPosted: Sat Dec 25, 2010 11:57 am    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
Even when the 3point hitch is not in use and in the lowered position, the loader arms and bucket do not operate smoothly. We use trans hydraulic oil but not a JD product. Does this make a difference? Have not had a look with light yet, but will. We are always checking fluid levels and keep trans Hyd. topped up. Loader is a 145 and dealer installed. Loader worked fine for years, is a recent problem. trying to cover bases before resorting to a pump rebuild.
buickanddeere
PostPosted: Sat Dec 25, 2010 5:01 pm    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
If you want you can search "rebuilt pump" on this site. You will find dozens of tractor owners who have replaced one or both pumps and the hydraulics still don't work.
If the operator hasn't kept the oil and filters clean. The low pressure trans pump relief and divert valves will chatter which shakes the transmission lines. These lines will split,crack or pop loose. Or the valves will stick from dirt or even from a lost filter "O"ring.
Is the pto operated from a 2-stage clutch or hydraulically engaged? A leak can occur in the pto clutch or the pto brake.
Is there a hydraulic rabbit-turtle transmission shift on the tractor?
The front pump will have problems if there is a high pressure side leak in the power steering, rockshaft or the loader control valves. It sounds like the rockshaft maybe the culprit?
I'm wonder when you keep answering "the dealer connected the loader"? Connected where? Into the hydraulic scv's at the back of the tractor? Or direct from the high pressure line and returns to a port in the transmission filter cover?
It makes a DIFFERENCE.
Using oil other than JD Hy-Gard will cause problems, from mild to severe.Ranging from chattering/jumpy brakes. Up to chemically breaking down the wet clutches and brake friction material.
Tx Jim
PostPosted: Sun Dec 26, 2010 4:03 am    Post subject: Re: Faulty hydraulics on 2130 john deere Reply to specific post Reply with quote
Murray Edgar wrote:
(quoted from post at 15:57:20 12/25/10) Loader is a 145 and dealer installed.
If loader has an independent hyd valve it's possible to have the convertible type(open to closed center) that an internal quad ring can leak letting valve revert back to open-center. I'd disconnect return line,run engine with both valve levers in neutral and see if oil flows out return line. Oil isn't suppose to flow with levers in neutral.
Also after changing hyd filter and checking screen I'd suggest checking stand-by pressure and set to 2350 psi.
As it's already been stated look inside oil filler hole for spraying oil with 3pt raised and engine running.
Post new topic    Today's Tractors Forum Index -> John Deere All times are GMT - 8 Hours
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
