Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
3010 Load Control Arm Seals
Post new topic    Today's Tractors Forum Index -> John Deere
Phillip921
PostPosted: Sun Jul 01, 2012 3:46 pm    Post subject: 3010 Load Control Arm Seals Reply to specific post Reply with quote
This will be the fourth time I have had to replace the load control arms seals in as many years. What could be the reason for them leaking so often? I feel sure that I"m installing them correctley.
Kansas4010
PostPosted: Sun Jul 01, 2012 4:52 pm    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
Replace the shaft as well and make sure you get shims in the cradle so it won't have any side play. If the shaft has any wear the new seals will leak. You don't want any play in the cradle either.
Mark-Ia
PostPosted: Sun Jul 01, 2012 10:16 pm    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
Get new style bushings and seals from Boling Manufacturing along with the shims.
Tx Jim
PostPosted: Mon Jul 02, 2012 2:26 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
I agree with he other 2 posters. Bolings seals instead of the JD seals along with a L/D shaft with no visible wear and remove all slack between drawbar support & trans.housing.
tim s
PostPosted: Mon Jul 02, 2012 3:06 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
I also use Deere seals "and" the Boling seals this gives a Double seal,and the excessive end play is what eats the seal in the first place...
M w J
PostPosted: Mon Jul 02, 2012 3:44 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
Are the boling seals better then the bushing with
seals in that you can still use the original seal
with also that deere sells?
Tx Jim
PostPosted: Mon Jul 02, 2012 4:04 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
M w J wrote:
(quoted from post at 07:44:17 07/02/12) Are the boling seals better then the bushing with
If JD seals a bushing with a seal I think it's a Boling.
Phillip921
PostPosted: Mon Jul 02, 2012 4:38 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
Thanks for all of the response, how do you eliminate the endplay? Are you talking about side-to-side?
Heat Houser
PostPosted: Mon Jul 02, 2012 5:23 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
Had the same thing on my 4010, never enough time to do it right so would slap a new set of seals in it. The root cause was the tapered bushing were worn, allowing "over movement" on the seals, crushing the seal's rubber. The tapered bushing are in the transmission case, and the "A frame" (the piece that the bottom 3 point arms attach to).
The tapered bushings allow the load control shaft to bend as the draft load increases on the two lower 3 point arms. The amount of bend is then transfered up through linkage to operate the 3 point valve to raise the arms during increasing load or to lower during decreasing load.
Replace the bushings, replace the load shaft (if bad/rusty/pitted), replace the seals, and shim out the side to side movement of the A frame. You should be good to go......
tim s
PostPosted: Mon Jul 02, 2012 5:53 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
Yes side to side,, Deere offers large OD shims in a few different thicknesses,add what it takes between the A frame and the transmission case, you can see the end play if you grab the 3pt arms and work them side to side against the sway blocks, as the hitch sways through out the day it continues to work on the seals till they fail.It helps to remove the lift arms for times when they aren"t needed , we usually take ours off the smaller tractors in the summer..when we are making hay or clipping pasture.
Tx Jim
PostPosted: Mon Jul 02, 2012 8:22 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
Here's a list of the shims(parts key #4) Tim was referring to.
R68425 WASHER AR 1.22MM (.048")
R68426 WASHER AR 0.91MM (.036")
R68427 WASHER AR 1.57MM (.062")
Phillip921
PostPosted: Mon Jul 02, 2012 9:21 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
How difficult is it to remove the bushings from the housing? Any tips would be appreciated.
M w J
PostPosted: Mon Jul 02, 2012 10:06 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
I do know the new ones I got from JD had had a seal
or o ring in the middle of the bushing . I didnt
take them apart to see if it was just an o ring or
not but They did come in a sealed john deere
plastic bag .
Tx Jim
PostPosted: Mon Jul 02, 2012 11:53 am    Post subject: Re: 3010 Load Control Arm Seals Reply to specific post Reply with quote
M w J
It appears you're correct. Here's the numbers for the bushing & o-ring for a pre '69 4020 BUT I couldn't find the same type bush/o-ring for a 3010 from JD.
R221297 BUSHING ADD 18.75 USD 18.75 USD
A3606R O-RING ADD 2.70 USD 2.70 USD
Post new topic    Today's Tractors Forum Index -> John Deere All times are GMT - 8 Hours
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
