Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
5020 has pto that quit
Post new topic    Today's Tractors Forum Index -> John Deere
gqjoe
PostPosted: Sat Jul 20, 2013 9:31 am    Post subject: 5020 has pto that quit Reply to specific post Reply with quote
Hi there, I have a 1967 John Deere 5020 that just had all its hyd oil flushed, rebuilt main hyd pump and cooler replaced with one that has a check valve up by the radiator. The other day i used it for harrowing and all of a sudden the tractor chattered as it had trouble lifting and dropping the harrows. The steering is beginning to act like there is air in the system too. Also now when i try the pto, it does nothing. Out of gear the shaft spins a little bit but while in gear, it turns really slow and theres no power it seems to it. Is it the gear pump? Can one fail so fast? I thought they gradually wear over time, not right away. Or do i need to try to adjust the pto engagement itself? Im at a standstill on this one and would appreciate any help.
Tx Jim
PostPosted: Sat Jul 20, 2013 10:26 am    Post subject: Re: 5020 has pto that quit Reply to specific post Reply with quote
I'll suggest to check pto hyd valve operating pressure. I'd think 150-160#s would be sufficient pressure
coonie minnie
PostPosted: Sat Jul 20, 2013 6:06 pm    Post subject: Re: 5020 has pto that quit Reply to specific post Reply with quote
I doubt the PTO problem is related to engagement, you questioned... given the other symptoms of wierd steering and poor performance with the hydraulic SCVs, I'd say you have a hydraulic issue somewhere. If I'm not mistaken, both PTO engagement and braking are done via the hydraulic system on these.
You mentioned the "gear pump"- I'm assuming you mean the transfer pump in the transmission that supplies oil to the main pump. When I had one of those fail, there was no hydraulics whatsoever.
I think you need to measure output from the main pump first, and then work back from there.
Checking the sump screen and filters would also be prudent before going too far.
gqjoe
PostPosted: Tue Jul 23, 2013 6:09 pm    Post subject: Re: 5020 has pto that quit Reply to specific post Reply with quote
Thank you for the reply, I will start from the main pump and work backwards. I just hope that I find a forgotten rag plugging the sump screen when I take it out and all my problems will be solved!!
gqjoe
PostPosted: Tue Jul 23, 2013 6:14 pm    Post subject: Re: 5020 has pto that quit Reply to specific post Reply with quote
Thanks for your reply, and to check the pressure at the pto
Hyd valve I place a gauge in the two plugs that need an Allen
wrench down beside the valve and filter area? I'm pretty sure I
know where you mean to check. Do you think that those
valves fail easily or are easy to adjust?
Thanks
Joe
Tx Jim
PostPosted: Wed Jul 24, 2013 3:40 am    Post subject: Re: 5020 has pto that quit Reply to specific post Reply with quote
I'd suggest to check trans pump flow. It should be in the 5 gpm range.
gqjoe
PostPosted: Wed Jul 31, 2013 6:10 pm    Post subject: Re: 5020 has pto that quit Reply to specific post Reply with quote
Thank you for your help guys. So far, I thought I"d check on the sump screen and after I drained the oil I found that my sump screen was very clogged up, almost looks like a rag was left inside when the rear diff lid was off. I changed the tractor from a 3 point hitch to one without earlier this spring. I guess I have some flushing and draining and cleaning in my future. I"ll run it now for a couple hours then drain and clean again. And then I"m going to check my pto and pump outputs to see where I"m running at.
Would anyone happen to know if there is demand for a 3point hitch set up? I have this extra one now and I"d sure like to find it a new home!!
Thanks again
Post new topic    Today's Tractors Forum Index -> John Deere All times are GMT - 8 Hours
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
