Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Massey Ferguson 135 firing problem
Post new topic    Today's Tractors Forum Index -> Massey Harris & Massey Ferguson
Jim Wolfenbarger
PostPosted: Sun Jun 24, 2007 1:14 pm    Post subject: Massey Ferguson 135 firing problem Reply to specific post Reply with quote
Recently bought this 4 cyl continental gas tractor. Replaced battery, plugs, and plug wires for good measure. Motor cranked hard but wouldn't start. Checked for spark at plugs, nothing there. Checked for spark at coil wire, nothing there. Replaced coil, still nothing. Replaced ignition switch and wiring from switch to coil and starter, still nothing. What else should I check for. Again, it cranks hard but no spark at coil wire. Any help would be appreciated.
Jerry/MT
PostPosted: Sun Jun 24, 2007 1:23 pm    Post subject: Re: Massey Ferguson 135 firing problem Reply to specific post Reply with quote
To check for spark, pull the center wire out of the distributor cap, hold it near a good ground, turn on the ignition and try a start. you should see A FAT, BLUISH-WHITE SPARK. If you don't, make sure that your points are set correctly, and are not pitted, burned or corroded. Make sure that your coil polarity is correct(the wire from the distributor to the coil should be attached to the coil terminal with the same sign as the battery ground terminal.).Make a jumper between the battery to the key side of the coil terminal and check the spark again. If you get the requisit FAT, BLUISH-WHITE SPARK, check the wiring between the battery, through the key switch, etc, to the coil.
Jim Wolfenbarger
PostPosted: Sun Jun 24, 2007 2:10 pm    Post subject: Re: Massey Ferguson 135 firing problem Reply to specific post Reply with quote
Would the coil not fire wether or not the points were good or bad?
Gerald J.
PostPosted: Sun Jun 24, 2007 5:08 pm    Post subject: Re: Massey Ferguson 135 firing problem Reply to specific post Reply with quote
The points must work right for the coil to fire. The points close and the current through the coil sets up a magnetic field. When the points open that field collapses an creates a high voltage in the windings of the coil. The points and condenser have to be good and working to get fire. Be sure the points aren't shorted by a pinched wire too.
Gerald J.
Jim Wolfenbarger
PostPosted: Sun Jun 24, 2007 6:21 pm    Post subject: Re: Massey Ferguson 135 firing problem Reply to specific post Reply with quote
I"ll pick up a tune up kit and give it a try. Thanks for all your help. Now I just have to hope the fuel system is okay.
Jerry/MT
PostPosted: Sun Jun 24, 2007 8:53 pm    Post subject: Re: Massey Ferguson 135 firing problem Reply to specific post Reply with quote
The points open and close the primary circuit. Current from the battery flows through the points when theyare closed and then stops when the points are open, collapsing the magnetic field in the coil which induces a a voltage in the secondary windings of the coil that fires the spark plug. SO the poits must conduct the maximum current while they are closed and must be closed for the right ammount of time. If the points have high resistance and are improperly set, the current will not be a maximum, nor will the duration be enough and the spark will be weak.
SO you have to have good points.
Post new topic    Today's Tractors Forum Index -> Massey Harris & Massey Ferguson All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
