Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Ford 9N Starter Installation
Post new topic    Today's Tractors Forum Index -> Ford 9N, 2N, 8N
Bob Myers
PostPosted: Wed Nov 18, 2009 9:10 am    Post subject: Ford 9N Starter Installation Reply to specific post Reply with quote
I have an issue of putting the starter back on my 9N. Bruce(Va)has offered some good advice,but I have had trouble responding so I'm starting a new posting. I can't quite get the starter into position to bolt in on. The teeth on the starter abut the flywheel teeth, but I can't move it sideways enough to engage it. This is the same starter I took off so I know it fit once. The hoe is egg-shaped, but I still need another 1/4 or so of movement. Any suggestions?
Danny in CO
PostPosted: Wed Nov 18, 2009 9:17 am    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
Bob,
Make the hole a little more egg-shaped.
Danny
souNdguy
PostPosted: Wed Nov 18, 2009 9:27 am    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
sound slike you have the drive in the 'engaged' position where it is sucked in close tot he starter face.. in that case, I'd either spin it back out on a wire wheel on my bench grinder or drill press, or rotate the drive a bit to try to get the teeth to line up and fall into place. They are a tough cookie to install when engaged.. but I've done it.
soundguy
Bruce (VA)
PostPosted: Wed Nov 18, 2009 2:24 pm    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
Did you engage the bendix while it was off? If it has the big spring on it, it's the old style; spin it back on the wire wheel on your bench grinder. If it doesn't have the big spring, post back for help on spinning it back; I slept through that class!
50 Tips
Bob Myers
PostPosted: Wed Nov 18, 2009 5:34 pm    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
Bruce, both you and "soundguy" mentioned using a wire brush to spin the starter back. I can move it back by hand fairly easily. Does this indicate a problem? The assembly has a 2" dia spring that is 1.5" long when assemabled and 1" when compressed. Is this what you are calling a big spring? Should the spring be compressed or not when assembling to the tractor?
Bruce (VA)
PostPosted: Thu Nov 19, 2009 6:14 am    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
When the starter motor turns, it draws the bendix forward on the shaft toward the starter motor. The bendix then engages the ring gear & turns the engine over. When the engine RPM's exceed the bendix design speed (which I can never remember)the bendix disengages.
Look at the gear on the bendix. If it is about 2 inches back on the shaft from the motor, it is disengaged.
50 Tips
don b 1
PostPosted: Thu Nov 19, 2009 8:38 am    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
Bob......did you remove the engine drain cock and oil canister?Doing this gives a lot more wiggle room. don b1
Bob Myers
PostPosted: Thu Nov 19, 2009 5:22 pm    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
Don, yes I have removed them. Thanks.
Bob
Bob Myers
PostPosted: Tue Nov 24, 2009 11:05 am    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
Soundguy, I think you must be correct that the starter is in the engaged position. I can rotate it by hand to the disengaged position but it won't stay there while I am jostling it around. Any other advice?
souNdguy
PostPosted: Tue Nov 24, 2009 11:56 am    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
you should not be able to rotate it to the out position by hand.. it usually has to be spun out by overspeed motion.
soundguy
Bob Myers
PostPosted: Tue Nov 24, 2009 5:52 pm    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
Thanks. I think you have given me the key. I probably cant get it installed because it isn't in the OUT position. There must be something wrong with the Bendix or me. So I will probably have to have a professional look it over. Thanks again.
Bob
souNdguy
PostPosted: Wed Nov 25, 2009 6:52 am    Post subject: Re: Ford 9N Starter Installation Reply to specific post Reply with quote
post a pic.
soundguy
Post new topic    Today's Tractors Forum Index -> Ford 9N, 2N, 8N All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
