Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Time For An Oil Change-MF 135
Post new topic    Today's Tractors Forum Index -> Massey Harris & Massey Ferguson
Trailgoat
PostPosted: Wed Nov 25, 2009 10:26 am    Post subject: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
I"m getting ready to change the oil on my MF 135. This is the first time I"ve ever done this. I"ve purchased the oil and the filter--I just need a little guidance. What"s the process? Drain the oil, change the filter, add the oil? My manual says it"ll take about 6.5 quarts--is this correct? Also, once changed, should I run the tractor for a while and then re-check the oil level? I just want to do this properly so I don"t screw anything up. I"ve got a knack for doing that to tractors. Smile Thanks, in advance.
DavidP, South Wales
PostPosted: Wed Nov 25, 2009 11:33 am    Post subject: Re: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
Hi,
You've got the procedure about right. I would run the engine to warm it up before draining.
Make sure you have a good fitting spanner on the sump plug. They are shallow headed and get damaged with the wrong spanner. Depending on the type of filter that you have; if its a screw-on cartridge smear some oil around the rubber seal and tighten to hand-tight. If its a paper element inside a canister; remove the canister and clean out. Make sure you don't loose the platform ring and spring. Using a small screwdriver prise the old ring out from the filter head. There may be more than one new ring present so make sure you use the correct one. Fit it very carefully taking care not to twist it otherwise you will have a leak. Refit the canister but do not overtighten. If you are able to fit a new copper washer under the bolt head, all well and good.
The 135 will take about 1.5 UK gallons. Fill with oil up to the full mark on the dipstick.
Turn the engine over a couple of times with the stop control 'OUT'. This will allow new oil to be circulated before the engine starts. Start the engine and check the oil gauge for pressure and the filter for any sign of a leak. When all is OK, stop the engine and leave for 3-5 minutes. Check the oil level and top up as required. Do not overfill.
DavidP South Wales
Trailgoat
PostPosted: Wed Nov 25, 2009 2:02 pm    Post subject: Re: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
Thanks for your response, David. I was hoping you"d respond--just from reading thousands of pages in the Massey archives, I can tell you nothing short of an "expert" on Masseys.
Just a couple of follow-up questions...
1. What"s a "spanner" and where is the "sump plug"?
2. You mention turning the engine "over" a few times with the stop control "out" to allow for new oil circulation. Makes complete sense, but what"s the technique? Also (excuse my tractor ignorance), what"s the "stop control"?
Obviously, I"m a tractor "newbie"--but, I"m not afraid to ask questions. Sure beats ruining a beautiful tractor. Smile
tg in VA
PostPosted: Wed Nov 25, 2009 3:23 pm    Post subject: Re: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
A spanner is a wrench
The sump plug is the oil drain plug on the side of the oil pan
David is suggesting you turn the engine over a couple of times with the key off (if it i a gasoline engine) or with the fuel shut off (if it is a diesel)
tg in VA
PostPosted: Wed Nov 25, 2009 3:27 pm    Post subject: Re: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
David is suggesting you trun the engine over (after you have changed the oil) with teh key off (if a gasoline engine) or with the fuel shut off (if a diesel).
DavidP, South Wales
PostPosted: Thu Nov 26, 2009 1:44 am    Post subject: Re: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
Hello, there you have it!
Two great nations seperated by a common language!!!
DavidP
C.JOSEPH
PostPosted: Sun Nov 29, 2009 1:44 pm    Post subject: Re: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
Hi
pls. advise type of engine and gear oil at min. ambyent temp. 25 deg. celcuse
Don-Wi
PostPosted: Sun Nov 29, 2009 8:01 pm    Post subject: Re: Time For An Oil Change-MF 135 Reply to specific post Reply with quote
Not sure what that translates to in fehrenheit, but sounds fairly warm. If so, a good Deisel rated 15w-40 for the engine, and at the absolute minimum a good trans/hydraulic fluid for the rear end. Massey's Perma-Tran 821XL is best however.
Donovan from Wisconsin
Post new topic    Today's Tractors Forum Index -> Massey Harris & Massey Ferguson All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
