Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Oliver 550 wiring question.
Post new topic    Today's Tractors Forum Index -> Oliver, Cletrac, Coop and Cockshutt
Gleanerguy
PostPosted: Thu Jul 01, 2010 9:36 am    Post subject: Oliver 550 wiring question. Reply to specific post Reply with quote
I am putting an alternator on my neighbor's 550 Oliver tractor (1964 model).
Presently it has a generator with an external regulator. The tractor has no ammeter. It has a positive grounding system.
I would be changing over to a standard negative grounding system with a one wire alternator with a built in regulator.
Am I correct- that I would need to switch the wires at the coil (the wire from the starter and the wire going to the distributor)? Thanks.
rvirgil_KS
PostPosted: Thu Jul 01, 2010 10:18 am    Post subject: Re: Oliver 550 wiring question. Reply to specific post Reply with quote
You are correct. With negative ground, the negative (-) terminal on the coil goes to the distributor.
If generator had a 3 wire regulator, remove generator and regulator along with Armature and Field wires. The wire on the BAT terminal of regulator will go to output of alternator.
If generator had a 4 wire regulator with L (Load) terminal you will need to connect the input of the starter and light switch to the alternator output.
Gleanerguy
PostPosted: Thu Jul 01, 2010 10:45 am    Post subject: Re: Oliver 550 wiring question. Reply to specific post Reply with quote
Thank you for your help, that's what I thought.
J. Schwiebert
PostPosted: Thu Jul 01, 2010 10:49 am    Post subject: Re: Oliver 550 wiring question. Reply to specific post Reply with quote
Except the existing wire may not have the capacity to handle alternator out put.
mmoore
PostPosted: Thu Jul 01, 2010 12:55 pm    Post subject: Re: Oliver 550 wiring question. Reply to specific post Reply with quote
The fuel and temp. gauges will not work corectly. You will need to buy a negative ground cluster gauge.
wmthrower
PostPosted: Wed Jul 07, 2010 4:46 am    Post subject: Re: Oliver 550 wiring question. Reply to specific post Reply with quote
That's right, you need to buy a new cluster guage. When you pull the old one out take notes of where all the wires go on the guage. There are some "jumper" wires between terminals.
Post new topic    Today's Tractors Forum Index -> Oliver, Cletrac, Coop and Cockshutt All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
