Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
5 row narrow on a Ih 715
Post new topic    Today's Tractors Forum Index -> Combines and Harvesters
mulcher
PostPosted: Wed Oct 20, 2010 7:41 pm    Post subject: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
Don't care how slow I have to go. Just can't go fast enough with a 3 row. I know a 4 row would be just right but the tires wouldn't be in the ditches. Would a 5 row break my 715?
Brian
NW Ohio Tim
PostPosted: Wed Oct 20, 2010 7:48 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
I'd kind of like to see a picture of the 5 row head you're looking for. I think they go from 4 to 6 row. Just as soon as I say there's no such thing, somebody will come up with one.
Tim
Hobby farmer 2000
PostPosted: Wed Oct 20, 2010 9:09 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
I have a 5 row 30 inch corn head. I run it on a 1420 IH. Works great!
dboll
PostPosted: Thu Oct 21, 2010 5:11 am    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
Case made a 1053 ch I am sure you could make one,it would be nice to use 9or10 series heads as they are lighter than 8 series ,we made an MF 5rn out of a 4rw and it works good. 715 should straddle 3n rows, might have to play with wheel spacing a little, I suspect 4rn on a 715 will run down corn rows thats why MF made offset heads.
Brad Gyde
PostPosted: Thu Oct 21, 2010 9:49 am    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
Had a neighbor that had a 5 row narrow on a 6620 Deere for a long time.. I never noticed it was a 5 row until he had a auction.. When I mentioned something to my grandpa, he said the owner said a 4 row was too small, and a 6 row was too big.. So he ordered in the 5 row.
As far as I know, it was an actual Deere built unit.. had a model number on it just like the 4 6 and 8 row heads.
Putting it on a 715, I can't help much.. but seems like it should be enough machine to run it, IMO
Brad
Fred Iron
PostPosted: Thu Oct 21, 2010 1:59 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
I went to a auction this summer where a guy had a 963 (6row)on a 715. He had added extra lift cylinders under the feederhouse. He also added a long drive shaft (maybe from a 915) under the feeder house so he could drive the head from both sides of the feederhouse.
Must have been really light in the a** end.
I have also seen 6 row 20 inch heads with plastic snouts (less weight) on 715s.
I think the question is how good is your corn crop and can the 715 handle the volume of material you will put through it
Duane966
PostPosted: Thu Oct 21, 2010 2:20 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
i ran an 843 on my 715 with no problems with the tires getting into the next row. this same head is now on my 1620. the grain tank on the 715 isn't all that big. tough enough with 4 rows to make a round. 4 rows would work the best and easiest one to find.
fwiw
Duane
IaGary
PostPosted: Thu Oct 21, 2010 6:02 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
Ran a 4 row 38 on a 1440 and 1660 for 27 years.
The tires ran on the rows not in between.
Put a set of stalk stompers on a 4 row and run it. That may be easier than trying to find a 5 row.
zane covert
PostPosted: Fri Oct 22, 2010 5:20 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
my owners manual for a 900 ih corn head gave a 5 row head in the models section. i think a 5 row head is built on a 4 row wide frame 40 in times 4 is 160in the tin is differant and some other parts would be also. poly snouts and a 900 or 1000 series head would be alot lighter than an 800 series.
Eric in IL
PostPosted: Sat Oct 23, 2010 1:15 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
I don't know if a 5 row would, but a 6 row broke the axle tube on my neighbors machine. He then used an axle from a 815.
Heat Houser
PostPosted: Sat Oct 23, 2010 2:28 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
Your comment about the Deere 5 row head....The 444 head (4 row wide) can be converted into a 543 (5 row narrow) without any frame modification. You need the narrow row center dividers and an extra row unit. Did this for a friend of mine, he went to an 8 row planter and only had a JD4400 combine. He ran this combination for 2 years and then got a JD 9510 and 8 row narrow.
Fordfarmer
PostPosted: Sat Oct 23, 2010 7:55 pm    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
If you can run a head that isn't matched to your planter... you must drive your planter straighter than I do! (or most guys around here, as far as that goes)
dboll
PostPosted: Sun Oct 24, 2010 5:39 am    Post subject: Re: 5 row narrow on a Ih 715 Reply to specific post Reply with quote
you plant with a 10rn planter, not hard to makea 10r out of an 8rw, I did it to my 7000jd planter
Post new topic    Today's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
