Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
4610 ford tractor steering
Post new topic    Today's Tractors Forum Index -> Ford
Birdman
PostPosted: Tue Feb 22, 2011 6:48 am    Post subject: 4610 ford tractor steering Reply to specific post Reply with quote
Hey guys, I have a 4610 ford tractor that the power steering quit working on. I imagine it's the little pump but I'm not sure. Is there any way of checking it without just R&R with a new one?
It started out weak without the engine at full RPM now it's just dead without any assistance at all.
souNdguy
PostPosted: Tue Feb 22, 2011 6:55 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
start by checking flow i guess.. see if the pump is doing anything at all.
soundguy
hurleyjd
PostPosted: Tue Feb 22, 2011 7:18 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
You might check the fluid level in the pump.
Birdman
PostPosted: Tue Feb 22, 2011 7:41 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
Haha, thanks...yeah I did that. It's full just not working.
Fordfarmer
PostPosted: Tue Feb 22, 2011 8:05 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
plugged filter?
sotxbill
PostPosted: Tue Feb 22, 2011 8:14 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
drain it.. fill it with 40wt oil, not 5w-40 but plain 40wt. if the pump starts to work a little bit, its a worn out pump. They cannot be rebuilt.
Jerry/MT
PostPosted: Tue Feb 22, 2011 8:27 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
It"s an external pump on the left hand side of the block. Is it full of fluid? There"s a filter inside the pump that needs changinging every once in awhile (every 1000 hrs), It"s less than $10 and you have to remove the pump and take the reservior off to get access. I"d change that first.
RodinNS
PostPosted: Tue Feb 22, 2011 10:11 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
Take the cap off the resevoir when the engine is running. If it appears to be circulating oil then you know the pump is turning... At that point I'd take the pump off and disassemble. Check to see if the housings are cut and the shaft bushings worn/gonzo. If they are, buy a new pump. If they're not then look at the releif valve in the pump. Could be some crap stuck in that and it's remaining open... More likely the pump is shot though...
Rod
Birdman
PostPosted: Tue Feb 22, 2011 10:51 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
Thats what I figured as well, I priced a new one this morning. Parts man told me he's try changing the filter first though, same as mentioned here.
Does the entire pump have to come off to replace the filter? If so I don't know that it's worth not just replacing the whole thing when I re-install the pump.
Fordfarmer
PostPosted: Tue Feb 22, 2011 11:22 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
No need to pull the pump to change the filer - reservoir can be pulled with the pump in place.
Birdman
PostPosted: Tue Feb 22, 2011 11:42 am    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
Thats the way I understood my parts guy but I thought someone here said to pull the whole pump.
I knew it would probably be obvious tomorrow when I ge tthe filter and start on it but it's good to know now.
Thanks!
RodinNS
PostPosted: Tue Feb 22, 2011 1:56 pm    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
No, don't take the pump off to change the filter. You probably need to remove the engine oil filter... and a steering cooler if it has one, then just remove the resevoir.
That said... the filter is a return filter so I don't expect that changing the filter will do anything for you other than liberate 20 bucks from you wallet. If the filter was bad the return releif valve would pop off or it would blow the filter to pieces... but it would still have steering pressure...
Rod
Jerry/MT
PostPosted: Tue Feb 22, 2011 3:19 pm    Post subject: Re: 4610 ford tractor steering Reply to specific post Reply with quote
It didn"t work that way with mine. I could not get the reservior off in place.
Post new topic    Today's Tractors Forum Index -> Ford All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
