Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Propane filling
Post new topic    Today's Tractors Forum Index -> Tractor Talk
farmer101IL
PostPosted: Wed Feb 23, 2011 7:42 pm    Post subject: Propane filling Reply to specific post Reply with quote
How do you fill propane tractors at home...Is there a cheap way? Or do you have to buy a pump system to fill the tractors tank..?? How did they do it in the days when they were being built.?? Do you have to have a special tank to pump from??
Thanks guys
Farmer 101IL
37 Cghief
PostPosted: Wed Feb 23, 2011 8:23 pm    Post subject: Re: Propane filling Reply to specific post Reply with quote
I just bleed the air out of the tank as it was filling, until you would see liquid comming out the vent hole. I don't think I would smoke doing this. I guess you would lose some fuel this way, but a pump isn't necessary. I stoped using propane, as the company came and took their 499 gal. tank, because not enough fuel was being used. Now the tractors just sit. I have the same tractors set up for gas, which is much easier. Stan
greenbeanman in Kansas
PostPosted: Wed Feb 23, 2011 9:10 pm    Post subject: Re: Propane filling Reply to specific post Reply with quote
You fill from a nurse tank, which is a tank that has what is called a wet leg, or a connection on the bottom of the tank. Basically the wet leg is a tube extending to the bottom of the tank with a valve above. Pressure within the tank forces liquid propane up the line and into a hose which hooks to the tractor tank. A fitting can be removed on the bottom of the tank to accommodate a valve and hose, but I'm of the opinion that isn't very safe. There wouldn't be a safety valve in it to stop excess flow should it be broken off.
Liquid propane begins to boil at -44ยบ F so anything above that creates vapor (gas) similar to steam coming off of boiling water.
The larger nurse tank has more surface exposed to the elements so boils liquid more readily than the smaller tank of the tractor. When the pressure equalizes liquid from the larger tank ceases to flow so vapor pressure is bled from the smaller tank so that liquid can continue to move fill its space. There are alternatives, but that is the general way farmers fill their tractors without a pump or compressor.
To relieve the pressure within the smaller vessel a special fitting is applied to the tank vapor return fitting and when screwed partially down it allows vapor to escape. Generally a hose is attached to carry the vapor downwind.
As I previously mentioned tanks have safety valves which snap shut if there is a large amount of flow too quickly. When beginning to fill if you open the hose valve too quickly sometimes the safety will close off the flow. You can generally hear such. Just close the valve to allow it to reopen and proceed again.
Cheap, yes. A valve and hose and a couple of other fittings will allow you to do the process. With a bottle POL fitting you can also fill bottles. Oops, that is old school for the older style valve. The newer ones do have a different fitting though I think the POL one will fill those too.
Have filled my share of tractors; G 705, G VI, M-5, a Massey Ferguson, pickups, delivery trucks, and a few million gallons to homes and oil field engines. I used to work for a dealer (7 years), but dad and I had the tractors.
I hope I wasn't too in-depth.
Nebraska Cowman
PostPosted: Thu Feb 24, 2011 4:16 am    Post subject: Re: Propane filling Reply to specific post Reply with quote
No pump need. See greenbean's post below, he has it
pretty well covered. I have had my driver fill the
tractor directly from the truck too. And if's farm
use it may be tax free depending on your state
rules.
Wardner
PostPosted: Thu Feb 24, 2011 9:01 am    Post subject: Re: Propane filling Reply to specific post Reply with quote
The L.P. can also gurgle in provided the storage tank is above the tractor tank. This would be a gravity fill. Quicker still would be two lines between tank and tractor; a vent line and a product line. The advantage of both methods is there is no waste or explosion hazard from vented propane.
I doubt if many people do it this way. A pressure fill at the farm requires venting the tractor tank.
Now don't ask me how they fill single port 20# or 100# tanks. They are frequently done inside and on a weight scale. No venting required. 33# and 40# forklift tanks are vented when being filled. Scale not required as liquid escapes through vent when filled to 80% capacity.
PostPosted: Thu Feb 24, 2011 12:32 pm    Post subject: Re: Propane filling Reply to specific post Reply with quote
Another option I just learned of is that of a hand pump shown at the link. It appears to compress vapor so I assume it works like the old compressor system we used to use to fill truck.
Worked like a wet leg tube in a barrel of liquid and when pressure is added to the barrel the liquid follows the path of least resistance and moves through the wet leg.
The old John Blue propane pumps worked well too. A Google image search shows one.
Krug hand pump.
Frank A
PostPosted: Thu Feb 24, 2011 3:51 pm    Post subject: Re: Propane filling Reply to specific post Reply with quote
If you're not in a hurry most of the time you can hook it up and leave it overnight and the temperature change will do the job. I made an adapter to hook up a disposable cylinder to get the tractor back home if I need to use the tractor alot. It will fill fairly quickly when empty.
kendak
PostPosted: Thu Feb 24, 2011 6:31 pm    Post subject: Re: Propane filling Reply to specific post Reply with quote
you can fill a JD 720/730 in less than 10min. without a pump...hook liquid line off your house tank to fill [liquid] valve & put a short bleed valve on vapor [bleed] valve & let it shoot straight up until liquid comes out ..you're done...studies done in the 60's show less than 1% fuel loss...been doing it that way since the late 50's...also down here in the south tractor LP is cheaper the fill line makes it your nurse tank NOT your house tank so fuel is cheaper...take care ...Kent
Post new topic    Today's Tractors Forum Index -> Tractor Talk All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
