Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Sickle mower on a Jubilee?
Post new topic    Today's Tractors Forum Index -> Ford 9N, 2N, 8N
TBprnaa
PostPosted: Mon Jun 20, 2011 1:40 pm    Post subject: Sickle mower on a Jubilee? Reply to specific post Reply with quote
Anyone use a sickle mower on their Jubilee? What size and is it run directly off pto or is there a belt/pulley involved. How does it handle tall and thick grass? Any ideas on cost for a Ford or similar mower? Thanks for any input.
hippie1st
PostPosted: Mon Jun 20, 2011 2:22 pm    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
Would like to find one myself. With a down angle for ditch mowing.
Ken-Pa
PostPosted: Mon Jun 20, 2011 3:59 pm    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
Hi, now not knowing whether you are leaning toward a rear 3 point sickle bar mower or the belly mount style . But either mower is run by a belt system connected to a double puuley on the PTO shaft . Lifting the cutter bar is thru the tractors hyd lift system . Now before buying a used sicle mower , think hard because if you buy & install the belly mount #14- ? mower , realize your tractor will now be a designated mower . But, if you buy & install a rear mount 3 pt sickle mower , it's much like any other 3 pt implement to remove so that you can use the tractor for another project . The cutter bars came 6' and 7'. I hope I've helped . Good luck with your decision & God bless, Ken
old
PostPosted: Mon Jun 20, 2011 4:28 pm    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
There are a good number of 3 point sickle mowers that work well on a Jubilee. The 501 or 515 Ford mowers as well as a good many NH and MF mowers. You want something under 9 foot say 7 foot for most stuff. I see them on Craig's list off and on all the time
Dean
PostPosted: Mon Jun 20, 2011 5:00 pm    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
Any N can easily handle a sickle bar mower as these mowers are very efficient and require little HP if in decent condition.
They are better suited to tall crops than shorter crops and work best when operated at relatively high ground speed as compared to rotary cutters.
The cover must be clean, however, and they are not suited for brush, rocks, saplings, etc.
Dean
TBprnaa
PostPosted: Mon Jun 20, 2011 5:14 pm    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
Thanks to all for the information and comments. I was curious as there was (now sold) Ford 501 for sale nearby. Not sure what it sold for but seller was asking $350 and photos showed it in pretty nice condition.
Scott(Ks.)
PostPosted: Mon Jun 20, 2011 7:21 pm    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
Several years ago I had a Ford 501, 7' mower on my 51 8N. That was a really good combination and on a Jubilee or 600 series tractor would be even better. I had good hay ground and mowed mostly in third gear. I traded work with neighbors and could just about run over any other tractor mowing in the same field. Set up right, with a good sharp sickle you just cant beat a 501 and a Ford tractor.
old
PostPosted: Mon Jun 20, 2011 9:08 pm    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
$350 for one that is in good shape is not bad. Key to them is things like sections and guards and belts etc. Any part that can wear is what you need to look and and also welds that should not be there
Lumpy
PostPosted: Wed Jun 22, 2011 6:19 am    Post subject: Re: Sickle mower on a Jubilee? Reply to specific post Reply with quote
Hippie, you need a Ferguson Dyna-Balance sickle bar mower to be able to mow the down angle of a ditch bank. It will also mow practically straight up to. Best mower i've ever used. Pain in the a$$ to mount though!!! Can only be mounted on 8n and newer. WILL NOT fit a 2n or 9n.
Post new topic    Today's Tractors Forum Index -> Ford 9N, 2N, 8N All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
