| Author |
Message |
Rugerzz New User
Posted: Mon Jul 18, 2011 11:45 am Post subject: Ford 3000 Steering |
Cutting grass yesterday and the tractor would not turn left. It will turn right but when trying to turn left, the steering wheel seems to be unscrewing itself from the housing. The steering wheel will literally rise as you turn. I am just wondering how big of a job this will be and if anyone has had a similiar issue. This tractor unfortunatley does not have p/s. |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12437 Location: Twin Cities
Posted: Mon Jul 18, 2011 1:07 pm Post subject: Re: Ford 3000 Steering |
Seems to be a lot of guys lately with the same steering problem.
You have the classic symptoms of a failed upper steering shaft bearing. It is a thrust bearing that prevents the shaft from moving upwards when the wheel is turned. All too often those steering boxes are not lubed properly so that upper bearing gets dry and fails.
Steering boxes are very simple devices to repair. You will first need to remove the center hood and the cowl around the fuel tank to get at it.
Then take the upper portion of the column apart and you will see the problem. I suggest you remove the steering arms so you can remove the sector shafts and do a thorough job of inspecting and cleaning. Install new sector seals also. Refill with 90wt and you will probably be good for another 40 years. |
| Back to top |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
The upper thrust bearing in your steering box is shot. Dependent upon your abilities it can be an easy fix but time consuming due to the parts that must be removed to get the steering box off the tractor. |
| Back to top |
Posted: Mon Jul 18, 2011 1:11 pm Post subject: Re: Ford 3000 Steering |
Not often you see two posts go online in the same exact second. But I was first. So don't challenge me in a gun fight ala Matt Dillon.
wink |
| Back to top |
Rugerzz New User
Posted: Mon Jul 18, 2011 1:57 pm Post subject: Re: Ford 3000 Steering |
Thanks to all that replied. Any idea of the parts that will be needed ? |
| Back to top |
Posted: Mon Jul 18, 2011 2:06 pm Post subject: Re: Ford 3000 Steering |
What failed on you is probably part #10 and/or #16.
The seals you want to replace are #34.
| Back to top |
awhtx Tractor Guru
Posted: Mon Jul 18, 2011 6:22 pm Post subject: Re: Ford 3000 Steering |
You just have your clock set ahead. |
| Back to top |
Rugerzz New User
Posted: Sat Aug 13, 2011 5:26 pm Post subject: Re: Ford 3000 Steering |
How do you get the steering wheel off ? I removed the nut and tried to use a gear puller but the steering wheel is pretty weathered.I t is on there.... |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1684 Location: Southeast PA
Posted: Sun Aug 14, 2011 7:14 am Post subject: Re: Ford 3000 Steering |
They can get pretty stuck from rust over the years. Soak the shaft under the nut with PB Blast or something similar for a few days, and then put the nut back on loosely, just a few turns, and then stand up on the tractor and grab the wheel with two hands and pull alternately, first one side and then the other back and forth, and put your weight into it. It should break loose after a little while of doing this, and when it does you'll understand why I said to put the nut back on. If the nut's not there to keep the wheel from pulling all of the way off when it breaks loose, you'll probably fall backwards off of the tractor when it does. |
| Back to top |
Ruger New User
Posted: Fri Aug 19, 2011 3:07 pm Post subject: Re: Ford 3000 Steering |
ok, I got the steering completely off the tractor.Figured I would do it right and there was some water mixed in the grease. I have taken the housing off exposing the shaft. I havent seen any bearings however. How do you get the steering shaft loose or should I? I see the square block at the bottom of the steering shaft but I dont see how to remove it. My problem is the tractor will not turn left and the sttering wheel seems to unscrew. Help me get the old girl(02/14/1967)"Valentines day" going again... |
| Back to top |
MDW Regular
Joined: 01 Sep 2009 Posts: 51 Location: North East TN
| Back to top |
Ruger New User
Posted: Sat Sep 03, 2011 5:13 am Post subject: Re: Ford 3000 Steering |
Ok, I ordered the steering kit and it has two bearings and races in it. I did find on bearing(the casing anyway) inside the housing. Does the steering shaft come out of the housing and a bearing go underneath 9,7 and 8 on previous picture. How do you get it out to replace the lower bearing or should I not worry about that ? |
| Back to top |
