Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
4030 wiring problem
Post new topic    Today's Tractors Forum Index -> John Deere
travz500
PostPosted: Thu Sep 01, 2011 2:56 pm    Post subject: 4030 wiring problem Reply to specific post Reply with quote
on my 4030 soundgard cab the flashers and the rear lights dont always come on the problem is where the power goes into cab i can wiggle the wires and they come on. Not sure what 2 wires it is but you can wiggle the plug and they may stay on for 5 mins or 5 hours what is the best way to solve this problem
tim s
PostPosted: Thu Sep 01, 2011 3:22 pm    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
I get this a lot on older sound Guards, the gases from the battery tend to decompose the plugins for the cab, the best way to fix it is to replace the harness,,it's not as bad as it sounds. A lot of them come in with wires Jap-Snapped around the plug to keep things going,,a temporary fix..
2520=4010
PostPosted: Thu Sep 01, 2011 3:55 pm    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
I had a tractor that had this problem. I pulled the plug apart and tried my best to clean the plug ends as best I could....I think I used starting fluid? Anyway, when I had it as clean as I could get it, I hooked them together and used #1 silicon to cover the plugs so dirt and air couldn't get back inside the plug. It solved my problem. HTHs
travz500
PostPosted: Thu Sep 01, 2011 4:17 pm    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
i already took apart last year when i had this problem clean with electrical cleaner and put on dielectric grease now problem is back does the harness come in sections or a whole kit? and where and what is the best book for wiring diagrams and repairs on the 4030 think we are gonna keep it for a feeding tractor so now i really need the lights
tim s
PostPosted: Thu Sep 01, 2011 4:43 pm    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
Get on the Deere web site they sell them separately,be sure to pay attention to the serial No. breaks, the Deere tech manual has good diagrams,,B&D will tell you how to get one :>)....
travz500
PostPosted: Thu Sep 01, 2011 5:51 pm    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
thank you sir
LarrySTN
PostPosted: Thu Sep 01, 2011 8:33 pm    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
There are tools that look like tiny screw drivers to get into the plastic connetors and remove the male and female electrical ends. You can also buy the new ends to put back into the plastic connectors. If the rest of the wiring harness is good, it is much cheaper to rebuild the connector than replace the harness. And it is much less labor. We have repaired many many connectors by just placing the guts (ends)
Hogleg
PostPosted: Fri Sep 02, 2011 5:20 am    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
don't know if they are the same or not, but Radio shack has a lot of those connector parts in their parts bins. May want to take a look. They are Molex if I recall correctly. May or may not work.
Also, Napa sells some of those style parts. Had to build one to make a connector on the Ford F250 to convert it for an exhaust brake a while ago. Basically bayonet male and female that insert into a plug housing.
YMMV.
John
tim s
PostPosted: Fri Sep 02, 2011 5:30 am    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
Repairing the connector end is all okay, but if the wire has turned Green up a few inches past that point, and the rest of the harness is equally in rough shape it is a much better fix to replace the harness, and again it is not a bad job.
JMS/.MN
PostPosted: Fri Sep 02, 2011 8:49 pm    Post subject: Re: 4030 wiring problem Reply to specific post Reply with quote
My local dealer prints out the diagrams for me- even multi page ones. Color coded so easy to follow. No charge.
Post new topic    Today's Tractors Forum Index -> John Deere All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
