Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
ford 5000 tach drive
Post new topic    Today's Tractors Forum Index -> Ford
TSJ
PostPosted: Fri Feb 10, 2012 6:17 pm    Post subject: ford 5000 tach drive Reply to specific post Reply with quote
I recently put an alternator on my 1969 Ford 5000
but have not been able to figure out how to hook up the tach. I believe it is counter clockwise.
Is there a drive unit that can get things together? Any help wold be appreicated. Thanks
Tj
awhtx
PostPosted: Fri Feb 10, 2012 6:54 pm    Post subject: Re: ford 5000 tach drive Reply to specific post Reply with quote
What kind of alternator did you use? If your 69 5000 originally had a generator like my 67 5000 the tach was driven off of the rear of the generator. You can buy an alternator with the tach drive but they aren't cheap.
TSJ
PostPosted: Fri Feb 10, 2012 7:04 pm    Post subject: Re: ford 5000 tach drive Reply to specific post Reply with quote
My 5000 also had a tach drive on the back of the generator,the replacement is a single wire alternator (delco) I think, but there is what looks like a
place on the left side of the motor,that some kind of a drive unit would go.Any Ideas there???
RodinNS
PostPosted: Fri Feb 10, 2012 7:53 pm    Post subject: Re: ford 5000 tach drive Reply to specific post Reply with quote
Newer engine had a drive in the arpeture below the oil filter... but a '69' block will NOT have the correct machining to support that. If it has the threaded plug in that hole it will not work.
If it's got a welch type plug it can be adapted to use the tach drive. That will also require changing the instruments over to the newer cluster... so you're into a few hundred bucks more when all is said and done.
Rod
Fordfarmer
PostPosted: Fri Feb 10, 2012 8:39 pm    Post subject: Re: ford 5000 tach drive Reply to specific post Reply with quote
7000's had their tach driven off the back of the injection pump. Would it be feasible to add that drive to a 5000's pump? Could use existing cluster, then.
chevytaHOE5674
PostPosted: Fri Feb 10, 2012 9:37 pm    Post subject: Re: ford 5000 tach drive Reply to specific post Reply with quote
Would it be possible to add the alternator someplace else on the motor and leave the generator in place to serve as a tach drive? Could gut the inside of the generator leaving only what is necessary to drive the tach? Just a thought at 12:30am... haha
Ultradog MN
PostPosted: Sat Feb 11, 2012 5:19 am    Post subject: Re: ford 5000 tach drive Reply to specific post Reply with quote
Never thought of it but it might/could be done. Remove the cover on the left, rear side of the engine and drive the tach off the cam. That is where they drove the tach on the old Hundred Series - off the end of the hyd pump.
Post new topic    Today's Tractors Forum Index -> Ford All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
