Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Farmall super C engine in Farmall C??
Post new topic    Today's Tractors Forum Index -> Farmall & International Harvester (IHC)
DanTo
PostPosted: Sun Feb 26, 2012 8:40 pm    Post subject: Farmall super C engine in Farmall C?? Reply to specific post Reply with quote
Can a Farmall Super C engine be put in a Farmall C tractor. I have a Super C with a good engine, and a Nice C that needs an engine and wondering if the engines will interchange without any problems? I do know the Super C has a water pump, but does that have to be used? Anyway, wondering?
uncle henry
PostPosted: Sun Feb 26, 2012 8:45 pm    Post subject: Re: Farmall super C engine in Farmall C?? Reply to specific post Reply with quote
yes it can also a 200 will work
gene bender
PostPosted: Sun Feb 26, 2012 9:50 pm    Post subject: Re: Farmall super C engine in Farmall C?? Reply to specific post Reply with quote
Water pump does not need to be used on either engine cause lots of the Cs have the SC kits and dont use the pump.
LMack
PostPosted: Mon Feb 27, 2012 7:58 pm    Post subject: Re: Farmall super C engine in Farmall C?? Reply to specific post Reply with quote
I think (you do need to get more information) that the water pump problem will give you some grief. If you try to install the SC engine with the water pump in place there is space problems with the C. If you delete the water pump there may be bolt up problems. You will end up bringing over the entire front bolster from the SC and the radiator for the SC is taller. The tin will not fit. The C engine is easy to rebuild. You need sleeves and possibly pistons. If the crank is in good condition no machine shop work is needed on the bottom of the engine. You would need a typical valve job on the top which might be a machine shop job. It is possible to oversize the pistons using larger sleeves and achieve the same displacement as the SC. Why swap out the engine?
Bill Krosnicki
PostPosted: Tue Feb 28, 2012 2:36 am    Post subject: Re: Farmall super C engine in Farmall C?? Reply to specific post Reply with quote
If the super C has the good engine, why not use it instead of swapping?
gene bender
PostPosted: Tue Feb 28, 2012 4:44 am    Post subject: Re: Farmall super C engine in Farmall C?? Reply to specific post Reply with quote
You are all messed up with your info the blocks are the same. The water pump will bolt on any A,B,orC and can be used without changing radiators it has been done many many times. The only difference in bolsters is where the steering in-put shaft is. You can put a Bs steering if you would like and by the same the Cs could be used on a B if you wanted. Ive seen a B with seat moved to the center above the tranny and a Cs steering sector used.
Post new topic    Today's Tractors Forum Index -> Farmall & International Harvester (IHC) All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
