case 930 ck pto
chris83093000
Guest
PostPosted: Thu Jan 21, 2010 8:04 am    Post subject: case 930 ck pto Reply to specific post Reply with quote
hi i was wondering if there is a way to set the pto clutch up so it grabs more seems to slip easier then it should does anyone have any pics of it thanks
bradley martin
PostPosted: Thu Jan 21, 2010 8:49 am    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
Yes, the clutch is adjustaable. It is not that difficult, but you will need a shop manual (I&T will work) a special tool (which you can make yourself) and likely a flashlight. There is a screw collar on the PTO clutch, secured by 2 pins(1 engaged, 1 disengaged) to keep it from turning on its own. You will need to pull the engaged pin and turn the collar a notch at a time until the lever requires about 50 lbs pull to snap it in.
Highly recommend that you do not continue using PTO until properly adjusted as you will do serious damage to clutch.
chris83093000
Guest
PostPosted: Thu Jan 21, 2010 11:57 am    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
were is this collar located on the tractor
bradley martin
PostPosted: Thu Jan 21, 2010 2:08 pm    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
inside the PTO housing.
DWalsh
PostPosted: Thu Jan 21, 2010 7:05 pm    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
There is a plate with 3 bolts on the upper right side of the housing that needs to be removed to adjust it.
chris83093000
Guest
PostPosted: Fri Jan 22, 2010 11:48 am    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
hi i just wondered do i turn it ccw or cw thanks
oldabe30
Guest
PostPosted: Sat Jan 23, 2010 3:23 am    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
some models are cw and the others are ccw, ive got two the same year one turns one way the other turns the otherway, just turn one direction a little and check the pull on your pto hand lever. if its tighter your doing right.
chris8309300
Guest
PostPosted: Tue Jan 26, 2010 5:55 pm    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
hi i located the plate had it off i think its the right one slides onto the pto engaging shaft,now am i looking in there for a pin that i have to pull back
oldabe30
Guest
PostPosted: Wed Jan 27, 2010 3:57 am    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
Have you got her fixed, just wondering.
chris83093000
Guest
PostPosted: Wed Jan 27, 2010 2:43 pm    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
no i havent yet i opened it up but i wasnt sure what i had to adjust i think il get a manual
chris83093000
Guest
PostPosted: Fri Jan 29, 2010 5:25 pm    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
hi i got a manual it says turn the collar after i unlock the pin how do i turn the collar do i turn the pto shaft on the back to do this
oldabe30
Guest
PostPosted: Sat Jan 30, 2010 2:22 am    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
Turn the collar.
Kav
PostPosted: Sat Jan 30, 2010 6:38 am    Post subject: Re: case 930 ck pto Reply to specific post Reply with quote
Hi everybody, I found another easy way to adjust the PTO clutch is to hold the pin out while somebody else turns the motor forward or backward, depending on the model and age. Don't forget that the clutch is a bit tighter when you replace the cover on the side which supports the cross shaft. It is well worth making a tool to pull the pins by splitting, heating and making a little curved claw on the end of a half inch screwdriver blade. Best regards - Michael.
