6000 starter
gary in neb.
Guest
PostPosted: Wed Feb 03, 2010 5:13 pm    Post subject: 6000 starter Reply to specific post Reply with quote
ok, so found out the starter on the 6000 i'm rebuilding is bad. according to the tag a 1113138 delco it's a 30mt. where is a good place to find one,should i go to a bigger size? i have one here for my 4020 deere that looks bout the same, anyone have options?
thanks
souNdguy
PostPosted: Wed Feb 03, 2010 7:14 pm    Post subject: Re: 6000 starter Reply to specific post Reply with quote
Normally I run a bad starter by a rebuilder as I like to keep oem starter's and gens, vs new overseas model.
if it turns out to be unrebuildable.. then price new ones.
this site claims to have one, and / or the rebuilding supplies.
soundguy
Starter Assembly, New - 12 volt, 10 teeth, 4-12" diameter. For Models: 2000 diesel with Lucas 4-12" field case (1965-1991), 3000 diesel (1965-1991), 4000 diesel, 5000 gas or diesel, 6000 diesel, 6600 gas (1975-1978), 7000 diesel (1965-1991). Replaces Lucas# 26137, 26189, 26364, LRS230, Iskra # ISO624. (Part No: D8NN11000CE)
ytmag parts
shaun wallace
PostPosted: Wed Feb 03, 2010 8:20 pm    Post subject: Re: 6000 starter Reply to specific post Reply with quote
That p/n wont work. 6000 starter on left side. Starter p/n C0NN11001A not serviced
gary in neb.
Guest
PostPosted: Thu Feb 04, 2010 5:52 am    Post subject: Re: 6000 starter Reply to specific post Reply with quote
the starter number 113138 is what is on the ford now. yes left hand side model. are you saying it's the wrong one on there? that could be, i dont know.
BDT in Minnesota
PostPosted: Thu Feb 04, 2010 11:11 am    Post subject: Re: 6000 starter Reply to specific post Reply with quote
Delco component will bear a Delco component number. (this case#1113138) this component, however, will be assigned a Ford part number by Ford Motor Company when used on a Ford product....
Check your yellow pages for a starter rebuilder in your area..
shaun wallace
PostPosted: Thu Feb 04, 2010 5:23 pm    Post subject: Re: 6000 starter Reply to specific post Reply with quote
I is meaning the one that is avaible from this site. Its a right hand mount.
Larry NCKS
PostPosted: Thu Feb 04, 2010 5:59 pm    Post subject: Re: 6000 starter Reply to specific post Reply with quote
gary in neb. wrote:
(quoted from post at 20:13:47 02/03/10) ok, so found out the starter on the 6000 i'm rebuilding is bad. according to the tag a 1113138 delco it's a 30mt. where is a good place to find one,should i go to a bigger size? i have one here for my 4020 deere that looks bout the same, anyone have options?
thanks
Gary, if worse comes to worst, there's a dang good rebuilder down Beatrice way. He doesn't charge an arm and a leg either. If he can't get it going for you, it isn't doable.
His name is Dave Spilker. His business is Spilker/Sprague Electric.
DaveH IA
PostPosted: Fri Feb 05, 2010 4:42 am    Post subject: Re: 6000 starter Reply to specific post Reply with quote
Good used one? 800 284 3001 ask for Dave
