67 C50 brakes
chris95
Guest
PostPosted: Sun Sep 05, 2010 4:46 pm    Post subject: 67 C50 brakes Reply to specific post Reply with quote
I have no front brakes. Rear ones work fine. The truck was sitting for two years. I suspect the wheel cylinders are froze, but I am having trouble trying to get at them. Do I have to take the hub off the spindle to remove the drum? Any advice is appreciated.
to_many_irons
PostPosted: Mon Sep 06, 2010 5:10 pm    Post subject: Re: 67 C50 brakes Reply to specific post Reply with quote
most likely but depends . do you have brake fliud at the bleeders .
was a brake line pluged with a nail . or coalasped brake line .
but it would be just as easy to pull the hub as a unit .
chris95
Guest
PostPosted: Tue Sep 07, 2010 3:29 pm    Post subject: Re: 67 C50 brakes Reply to specific post Reply with quote
No fluid at the bleeders. The brake lines look ok.
to_many_irons
PostPosted: Tue Sep 07, 2010 5:06 pm    Post subject: Re: 67 C50 brakes Reply to specific post Reply with quote
try bleeding where the brake lines go to the front from the booster .
just a note the front wheel bearings could probley be repaced . and its been a while since i worked on this stuff , i could be off a bit .
Repair
PostPosted: Mon Dec 06, 2010 2:33 pm    Post subject: Re: 67 C50 brakes Reply to specific post Reply with quote
Do you have a single reservor or a dual?
Take the rim off the casting & than the brake drum of the spindal, Can be a problem, Try to loosen the brakes, Put in new wheel cyl's.
Post new topic    Yesterday's Tractors Forum Index -> Yesterday's Trucks All times are GMT - 8 Hours
